Can't program remote
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's
right say it with me....He...Rocks...hehe...but anyway here is the link
address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
SOURCE: need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
SOURCE: program a vibe 4-in-1 remote
If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
