Question about Samsung Computers & Internet
No power in my monitor sod14m
Do not turn on the monitor, verify the fuse is ok.
  • Samsung Master
  • 3,320 Answers
Try a different AC outlet.
There are no user serviceable parts on these flat panel tvs.
Use your warranty if available. This is why buying the extended warranty on expensive electronics is a good policy.
Find a nearby electronics repair shop and get it checked over.
Posted on Mar 27, 2014
What causes a Syncmaster 2253LW monitor to start ok and immediately fade.
The monitor may be failing. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
How can case of DGM L1931 monitor be opened? How is stand fitted? Are there known problems that can be fixed?
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 11, 2014 | Computers & Internet
Moniter output not connect
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 20, 2014 | Computers & Internet
Yellow light
Change the power plu fuse for the second monitor.
Disconnect the data lead from the monitor and reconnect it
Feb 04, 2018 | IBM ThinkVision Computers & Internet
Peavey XR8600D main outs simply stopped working. Unit is less than a year old but I am too far from any repair shop to make any use of the warranties (Samoa, South Pacific). I turned it on one night and...
These had a little switch on the far right side that shifted modes from stereo to main and monitor. Check the position as it is tiny push button. Also try sending line levels DIRECTELY into the power amp inpout jacks to verify the amps are both OK... if not, the repair shop is only option... there is only one main fuse for the amp and if one side is working, then the fuse is good.
Oct 29, 2011 | Peavey XR 8600D Class D Powered Mixer
Monitor will not turn back on
Verify that you have 120 VAC coming in. If this is TRUE; You probably have a blown SEL fuse. You did not say whether or not you get a green, yellow, orange, red light on the front indicator LEDs? This will also verify if power is being supplied to the unit. Did you have a surge suppessor between the wall power outlet and the monitor? Voltage spikes can kill these monitors. TCC
Feb 02, 2011 | LG 22" FLATRON LCD Monitor
Can't hear volume from my monitor
We need to find out if the problem is in the monitor or at the PC sound card. Try feeding the monitor with sound sound source such as MP3 player to the audio line in of the monitor to see if you get the sound or not. If you do not, then you will need to open up the monitor and inspect the audio power amplifier circuits. If you get the sound OK, then verify that the cable between the PC audio line out (green jack) and the monitor audio input (green jack), next verify that the audio level controls (on screen volume control panel) are set up OK, not at minimum setting. Verify that correct driver for the sound card is installed.
Apr 29, 2010 | Hannspree HW191D LCD Monitor
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
My monitor will no turn on what do i do
1. Verify power cord is plugged-in and supplying power to monitor.
2. Verify Cord in between CPU & monitor is responding. (if it doesn't it will display Dell logo on dell monitors).
3. Press Power button and see LED turns green.
Sep 12, 2009 | Dell Computers & Internet
No power to monitor
Your problem is really multiple problems. One is if the monitor blew out, the second is weather it damaged the computer when it went, the third is if the computer went first killin the monitor. I would first see if your computer is ok by turning it on with out any monitor connected and listen to hear if it sounds as usual. If not something may be wrong with your computer. If everything is ok plug in another monitor (borrow from a freind if you do not have a spare) and see that the computer is ok. If it's ok great but if there is a problem with the computer that is a whole new question.Next if the monitor's on light does not come on and you know it has power the monitor is most likely fried. Hope this helps and could use more details
Dec 29, 2006 | NEC MultiSync LCD1550ME (Black) 15" LCD...
Computers & Internet Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
