Question about Samsung Televison & Video
How to lock panel on Samsung plasma PS42C450B1LXL. I want to operate TVA only with remote so that my naughty kid doesn't change the channels herself.
4 Suggested Answers
  • 1632 Answers
SOURCE: plasma tv frozen or locked and remote and tv buttons dont work
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
henna4641
SOURCE: Can't change channels on Samsung LT-P1545
http://www.avforums.com/threads/cannot-change-channel-on-samsung-le26r74bd.839670/
The solution posted here worked for me.
Posted on Dec 19, 2013
I need to know how to change my tv to channel 3 without the remote.
look along the side right or left and there is a row of buttons . they do all the functions a remote will
Mar 06, 2015 | Samsung Televison & Video
I lost the remote to my lg plasma 42lg 30tv and can not get the key lock off without my remote. How can I get it off key lock and change the channel
Why dont you purchase a universal audio remote control from your local audio and TV store or use a Anroid mobile phone and download a universal TV remote APP
Dec 07, 2014 | Televison & Video
Cannot get sound to work
read the owner manual if you have it---if set has lockout feature unless it also locks remote you should be able to operate with remote.
A few sets have a lockout that affects both remote and keyboard buttons==if no owner manual Google for it by model number or visit the Samsung? site.
May 20, 2012 | Samsung PPM42S3 42 in. Plasma Television
Ihave spn 4235 plsama tv problem is keep scan channel and rase the valume by self also icanot use the remote control to use the tv for on and off just plug and unplug the wire power need help plz
First take the Batteries out of your remote control to see if the T.V. is still changing channels or not. If it stops changing the channels and volume, try opening the remote with a knife and clean all the pads with rubbing alcohol to prevent sticking buttons. Be careful if using a remote with a roller ball.
Jun 06, 2011 | Samsung SPN4235 42 in. Plasma HDTV
Lost remote can i still tune the channals
Hi, you can tune the channels of the Plasma TV without Remote Control. However, I suggest that you to purchase a new Remote Control of the same model number of the Plasma TV with any near by Plasma TV dealer.
Apr 07, 2011 | Samsung PS42B430 42 in. Plasma TV
My samsung flat screen tv the channels won't change on the tv or the remote
if you have already tried to re scan the channels and that did not work you are going to have to reaplce the Mainboard the cost is around 200 dollars and you should be able to find it on partsearch.com or Andrew electronics
Dec 10, 2009 | Samsung HP-T4254 42 in. Plasma Television
Trutech TV parental control
naughty naughty, we have been caught before!
Ask your parents to give you the password. Passwords are there to stop inquisitive kids from watching unsavoury things.
If you are an adult then use the Payable request to prove you are of age and not a child trying to subvert Mum and Dads password.
now go to your room and think about your punishment when your parents find out about this
Jul 05, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Panel locked
Remote needed:
When Panel Lock is set to ON, the buttons (SOURCE, MENU, VOLUME, SELECT, MUTE, POWER) on
the front of the PDP will not operate. However, these buttons will operate when setting Key Lock OFF.
1 Press the Menu button. Move the joystick up or
down to select “SETUP”, then press the joystick
to enter.
2 Move the joystick up or down to select “Panel
Lock”, then move the joystick left or right to select
“On” or “Off”.
3 Press the Menu button to exit.
Jun 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
