Sharp MX 2301n Fuser kit part number
Does anyone know the part number for the fuser kit And what the kit consists of?
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Posted on Jan 20, 2009
  • 53 Answers
SOURCE: Dell 1600N fuser replacement
1. Power Printer off and disconnect power cord.
2. Remove back cover.
3. Remove rightside cover
3. Disconnect the thermistor cable from the controller card. (rightside)
4. Disconnect the power cable from the power board. (bottom back of the printer)
5. Remove the 4 screws securing the Fuser assembly to the chassis.
6. Pull fuser out towards you.
7. Reverse the previous steps to replace the fuser.
Posted on May 07, 2009
zeroxparts
  • 15 Answers
SOURCE: I have a EX-3535 fuser error code 004-361 coming
4-361 Drum Motor
Drum Motor failure.
Initial Actions
• Remove all Drum Cartridges.
• Perform REP 1.6.
Procedure
The machine is a DC3535.
Y N
Enter dC330 [004-003] and press Start. The Drum Motor energizes and the drives
rotate.
Y N
Go to Figure 1 of this procedure and measure voltage between the Drum Motor P/
J210-4 (+) and GND (-). +5 VDC is measured.
Y N
Go to Figure 3 of the +5 VDC Wirenets and troubleshoot the problem.
Replace Drum Motor (PL 1.1).
Posted on Dec 01, 2009
Testimonial: "Excellent Diagnosis - I was wrong about the fuser and it was one of the drums very stiff so I changed it and all is well. Thanks"
otorres
  • 33 Answers
SOURCE: how do i replace fuser kit in hp p2015
you'll find the service manual for sure here!!
hope this helps...
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P2015%20Series%20Parts,%20Service%20Manual.pdf
Posted on Jan 21, 2010
What shall i do to return my sharp mx-2700n copier to operation?
have you check the sensor actuates on the registration section
Oct 19, 2015 | Sharp MX-2700N Color Copier
Sharp copier mx-2301n code L4-30 i need help
The fan blades are normally the problem, check the fans below the black toner there are 2 small fans. Make sure they are operational.
http://www.manualsprinter.com/manuals/sharp/Sharp_MX-2301N.pdf
the link should help you step by step trouble shoot.
Aug 28, 2015 | Sharp Office Equipment & Supplies
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
Sharp MX 4100n giving L4-16 error msg
Your machine has automatic fuser pressure control. It's supposed to release pressure when you shut it down, and reset it on startup. This is done by a combo of a motor & gear on the machine and a gear on the fuser. Somehow this has gotten reversed or jammed. you need to take the fuser out and make sure the gear is in the right position and that no rods are in the way (there's a cleaning rod resting on your lower fuser roller, often this will tuck under its' mounting rode and wedge)
Apr 02, 2014 | Sharp Office Equipment & Supplies
How to install fuser in mx 2300n
Hi
Open door on right, should be to blue screws holding the fuser unit in, remove the screws, then pull out fuser using the grey handles at either end of the unit.
Cheers
Andy
Feb 16, 2014 | Sharp MX-2300N Color Copier
Unable to print from my MacBook Pro using my printer Sharp MX-2301N
Does your unit have a PS3 expansion kit. if not you can only print using s PC, not a Mac. A work around is to use the Generic PCL driver available on later model Macs
May 13, 2012 | Sharp MX-3501N All-In-One Printer
SHARP MX-3501N: The following Error Code is displayed on our unit. H4-00 Error; Call for Service. I need to reset the code, but do not know how
this error is a fuser unit error. you cannot reset the error code without repairing or replacing the fuser unit.
Nov 16, 2009 | Toshiba e-Studio162D Copier
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
32 people viewed this question
jasbo
jasbo
