Question about Broilmaster Premium P3 Grill
Won't heat up above 200 degrees.
Grill is 8 years old. No problems to date. Last night the knobs were set to High. The grill started up but would never heat above 200 degrees with the lid closed. Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Posted on May 08, 2014
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Periodicly I won'y be able to get the grill temp to over 200 degrees. sometimes it is ok and can reach as high as 500 degrees other times it will just not generate enough heat to grill.This is a five...
zonfish - if you're tuning the gas tank off at each use, as you should. The problem lies in your grill's gas regulator, but it also is not a big deal and is easily solved.
Whenever, you open the tank valve, do it VERY, VERY, SLOWLY (Slow Motion, slow), until it is fully open. Then light the burners.
What happens is this, LP Gas Grill Tanks are now equipped with an Overfill Protection Device ("OPD"). And often time, when you turn the valve on like you would normally do, the OPD Valve sends a hot load of gas to your grill's regulator and partially locks it up or locks up entirely. Therefore, the burners are not getting enough gas to heat the unit up to 500 degrees. Opening the valve very, very, slowly, overcomes this problem.
I hope this helped you and Happy Grilling.
Jun 20, 2011 | Brinkmann 810-2300-B Grill
No matter how long I let it heat up never goes past 250 degrees
First, do the flames on the burners, when they're on high, appear to be normal? Or are they lower than normal, despite the burner knob(s) being turned to high? Do you turn the tank OFF after grilling each time?
If you answered yes, to the last two questions, here's what you need to do. Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve ON VERY, VERY SLOWLY, until it's completely open. Light each burner individually and turn the burner knob to high. Once all the burners are lit and turned to high, do the flames look taller than before?
If so, you just solved your problem. Remember to turn the tank valve on VERY, VERY SLOWLY each time you turn it ON.
If the above is not the problem, the grill thermostat may be faulty. To test this theory, purchase an inexpensive Oven Thermometer and place it on the grill grates, when preheating your grill. Close the lid of the grill and ten minutes later, take a look at the Oven Thermometer and compare it's temperature with the grill thermometer. If the grill thermometer is reading significantly lower than the Oven thermometer, you need to replace the grill thermometer. You can purchase one directly form Weber.
Hope this helped you solve your problem. Happy Grilling!
Feb 20, 2011 | Weber Genesis Silver B Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
The grill only reaches 200 degrees
PROBLEM
Barbecue temperature only
reaches 250° to 300° in the HIGH
position.
CHECK
The excess flow safety device,
which is part of the barbecue to
cylinder connection, may have
activated.
CURE
To reset the excess flow safety
device turn all burner control knobs
and the cylinder valve OFF.
Disconnect the regulator from the
cylinder. Turn burner control knobs to
HIGH. Wait at least 1 minute. Turn
burner control knobs OFF. Reconnect
the regulator to the cylinder. Turn
cylinder valve on slowly. Refer to
“Lighting Instructions”.
http://www.weber.com/manuals
Sep 07, 2009 | Weber Genesis Silver B Grill
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
May 22, 2009 | Weber Genesis Silver A Grill
2 year old Charmglow 4 burner grill barely heating to 200 on high
check the burners for debris such as..... a mud dobbers nest/ spiders.
Mar 22, 2009 | Brinkmann Charmglow Stainless Steel LP...
The temp/flame on my weber grill won't get hotter
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
Char Broil commercial grill won't heat pass 300 degrees
I had a similar problem and thought the propane kept running out....come to find out it was a defective regulator. $21 at the local ACE store as running to LOWES and trying to get a point across to a 17 yr old summer help college kid for a intermittent problem seemed more challenging then it was worth. Would barely light the burners and would not get over 200 degrees. Ripped it apart...blew through all the orfices including the regulator put it all back together and would work for a while then fail again. Good luck!
May 30, 2008 | Char-Broil Commercial Stainless Steel...
Broilmaster Premium P3 Grill Logo
234 people viewed this question
Top Broilmaster Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Broilmaster Grilling Expert? Answer questions, earn points and help others
