Question about Tappan TGF320 Gas Kitchen Range
Broiler turning on by itself
Sometimes I will go out in the kitchen and the boiler in the oven will be on with no one else home. Light is not lite showing that the boiler is on.
  • Ashley Noble Border
    Ashley Noble Border Mar 26, 2014
    It will be so hot I can't tough the stove. Why would it be turning on by itself?
  • 76 Answers
Probably a bad controller or relay, get it fixed or replaced.
Posted on Mar 26, 2014
2 Suggested Answers
  • 338 Answers
SOURCE: oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Posted on Nov 27, 2008
Burners n broiler lite up fine, oven will not .... pilot out?
Does it have electronic ignition or pilot. You don't say. Check the thermocouple. That is usually why most ovens fail even when overhead broiler works. The Thermocouple is a probe that heats up either by pilot or igniter and turns the gas on when it reaches the proper temperature. You can sometime take a little steel wool and clean off the probe..sometimes that will do it. Make certain you are cleaning the thermocouple and not the thermostat probe.. Thermocouples are right near the burner itself. If that does not work you will need a new one.. some screw out and can be replaced.. others may be sealed to the gas manifold. You will then have to call a repair man to replace it.
Mar 10, 2015 | Kitchen Ranges
Oven wont lite. broiler is ok. why? is this something i can fix myself?
Hello- Gas ranges have ignitors that light the burners. The lower burner is accessable by removing bottom pan in oven. Ignitor is held in place by two screws. Connector is plugged in behind bottom drawer. Check resistance of ignitor - should be 4ohms or higher. Sometimes they just break. New part available thru local app. parts. 50-75$. Be careful installing new part- ceramic ignitors are fragile. Take your time- toughest part is reaching in to do work. Hope this helps.- Thanks- ED
Feb 28, 2010 | Kenmore 72002 / 72004 Kitchen Range
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Oven burner seems to have low flame
Check voltage to gas valve in the back of the boiler compartment. It is way in the back on the left hand side, turn on the top burners. If you do not get any volts or only 1 to 5 volts you will need to replace, It is supposed to have 24 volts to operate correctly
Feb 09, 2009 | Jenn-Air JGS8850AD Gas Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven won't lite
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Oven will not light
ck your light bulb . and ck with meter see if you geting any voltidge
Feb 05, 2008 | Amana AGR5735QDS Gas Kitchen Range
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
44 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
