Question about JVC Xc-m75 Kenwood 6 Compact Disc Magazine Lot Of 5
Cartride won't eject
Disc cartridge will not eject
    Top Expert:
  • JVC Master
  • 34,763 Answers
The magazine may not be able to eject because a CD is stuck and not completely seated inside.
Posted on Mar 26, 2014
I have an 1990 JVC XL-M303BK Home Compact-Disc player (2 channel) and am unable to eject the 5-disc cartridge. Is there a solution for this ?
There is a CD jammed in transit between the playing mechanism and the magazine. Some disassembly will be necessary to get the disc into the magazine so it can be removed.
May 28, 2017 | Audio Players & Recorders
My 2003 chevrolet silverado says no discs when there are discs installed
Is this a internal 6 disk changer or a external one ,if external then eject the cartridge and remove all the CDs ,now insert the cartridge and if one is jammed it should remove itself into the cartridge when you press the eject cartridge button ,well this works on my jag
Nov 30, 2013 | 2001 Mercedes-Benz C-Class
Kenwood 10 Disc Cartridge won't eject
From your description it is likely that a CD is jammed in the player, preventing the magazine from being removed. Even though your Kenwood is hard to get to, it will have to be removed and disassembled to correct the problem
Feb 01, 2013 | Car Audio & Video
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
Lexmark x4650 refilled ink cartridge but printer says it's empty and won't print
Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
Jun 14, 2011 | Lexmark X2500 All-In-One Printer
Error 5...ink cartridge is not recognized after refilling
Clean the contact point of the cartridge to the printer before placing it, then **** some ink in the cartride by a cyringe to lessen the level of ink inside the cartridge. full ink cartridges encounter this error because the absorver inside the cartride overflows.
Mar 28, 2011 | Office Equipment & Supplies
Receive msg: "Print Cartridge(s) missing or not detected
i thing u have problem with your cartride try to buy orgnal cartride and try if not then you have to go to work shop becoz u r cartride slot if not working properly
Apr 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
Minolta 2530DL cartride reset problem
Take the cartridge to Cartridge World they will fix the issue they have fixed it for me in the past. They really know what they are doing just bring the cartridge to them and they will help you
Mar 29, 2009 | Minolta magicolor 2350 Laser Printer
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
Clarion 635
I just fixed mine and the problem was one of the cartridge trays that holds cd's had come out and was sitting outside the cartridge and over the top of the assembly that "collects" the disc to play.
If you can easily remove the entire unit from it's mounting brackets, then I have a solution. It might sound tricky, but it's actually pretty easy.
Once you've removed the entire unit, place it on a table to work on. Remove the front plate (this is the part that has the hinged door on it to protect the cartridge and inside mechanisms) by carefully sliding a thin flat screw driver along the plastic edge where it connects to the metal box. There are several tabs that just have a friction fit holding it in place. Be gentle as to not break the top plate.
Once the front plate is removed, you'll find two very small black screws on each side of the metal box/case containing the cd player. (The top half of the case.) Once you've removed the four small screws, you can lift off the top of the metal case and expose the cartride and cd player. At this point, you'll probably see that 1 or 2 of the cartride trays has come out of the cartride and are sitting over the top of the cd player. Gently push the trays back inside the cartridge.
Once the trays are back inside, you can take the entire back over to the power card, plug it in and see if when you hit the eject button if the cartridge pops out. If it does, you're almost done.
Go ahead and slide the top half of the metal box/case onto the unit. Replace the 4 small black screws on the sides. Replace the front plate carefully. Remount the unit in it's original location. Plug it in and you're done.
Feb 03, 2008 | Clarion DCZ625 6-Disc CD Changer
JVC Xc-m75 Kenwood 6 Compact Disc Magazine Lot Of 5 Logo
200 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
