Question about GE Dishwashers
Completely disassembled + tested GE dishwasher, but still won't drain
It's a model GLD4408R00WW. I replaced the drain screens (which were clogged with hard water deposits,) inspected the check valve, checked the drain loop + hose, removed both motors and tested by applying 110V, then ran it through a cycle with test lamps hooked to the motor leads to make sure they were getting power. BTW, the motor makes no noise at all when the cycle is ran with everything hooked up normally. I'm stumped on this. Everything apparently works, but it still doesn't drain.
    Problem Solver:
  • 8 Answers
Air Gap on the sink could be clogged.
Solenoid on the motor could be melted or overheated and it is not letting the check valve open.
Also the motor should make noise. It could be stuck so that it gets voltage but is not turning. You can hear it humming. Unplug the dishwasher and from the front underneath, you can see the fins of the motor. It should spin freely. If it is stuck, the you can force it free by turning the fins with a couple of screwdrivers.Sometime if you don't use the dishwasher weekly, the motor seals dry and gets stuck.
Posted on Apr 25, 2014
GE Dishwasher not draining on a new install but used unit.
Inspect drain hose for clog. There may be a check valve in it to prevent water from reentering the machine. I found a piece of a stainless steel scrub pad in mine. It would drain, but not completely. Remove the hose & run water thru it to test.
Aug 20, 2014 | GE Dishwashers
Dishwasher
Have you checked the drain hose inlet at the garbage disposal? This is a common clog area. Easy check by removing drain hose at disposal and inspecting. Warning, if the disposal is old, the dishwasher hose connector (nipple) may be weak and corroded if metal and may end up needing a new upper half or whole new disposal if part not available. If bad, better to find out now than to have it break loose at some point, flooding your kitchen.
Mar 26, 2014 | GE Dishwashers
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
Ge gdwt260r10ss won't drain
Probably one of two different things can cause this problem. Your dishwaser drain could be clogged you can take off the the drain and try to see if it is clear by using a vaccum cleaner reversed to try and blow air through the drain if clogged the air will be strickly hammpered or not getting through at all, if this is your problem then starting at the filtered drain and work your way to where the drain enters the house hold sewer. The blockage will some where between these points. The other possiblity is that the drainiagepump on the dishwasher is bad, you'll have to referre to your owners manual in order to see what it say about testing or replacing the pump. Hope this helps.
Aug 28, 2012 | GE Dishwashers
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
clogged strainer, clogged or kinked drain hose ,clogged pump, faulity motor,faulity drain valve. all can be disassembled and cleaned except motor & valve they need to be tested if u have a valve it can be repaired
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water not completely draining... hose not clogged.
Check all the above to address thsi issue.
Apr 15, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
GE diswasher GSD4020Z02BB doesn't completely drain
rs, in the back under the screen is a piston nut assy. This is a common problem on these GE's. The seal on the assy. becomes warped or worn and when this happens we get water left in the tub after drain. It's an easy fix. The screen comes off and the pistion nut assy. simply unscrews. The part number is WD24X220. You can look it up on the net, inexpensive. Catriver..post back.
Mar 05, 2007 | GE 24 in. GSD4020Z Built-in Dishwasher
Dishwasher dosen't drain completely
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Dec 08, 2006 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
