Question about Electrical Supplies
1999 Dodge Neon- all lights go out while driving
Light switch sometimes doesn't work or turns off by itself
  • 3 Answers
Have you checked for any recalls for that vehicle? Many dodge/chrysler vehicles had problems with the electrical shorting out either under the dash or at the firewall I think.I dont remember the specifics but its a place to start. Also, If all your instrument gauges, heater blower motor, and everything else electrical still works when the lights dont, its probably a bad switch.
Posted on Apr 06, 2014
My 2001 dodge neon, turn signals , hazards, and brake lights do not work. 3rd brake light does work though. Any ideas?
Maybe something wrong with multifunction switch? Your lower stop lamps are wired through the multifunction switch, the high mount stop lamp isn't wired that way. The lower brake lamps and turn signal, use the same bulb filament, just not at the same time. Sometimes, you can click on diagram to enlarge, if not, click on your highlighted post, sometimes on that page, you can enlarge.
Dec 16, 2016 | 2001 Dodge Neon
Find the fuse for a 1999 dodge neon dome light?
They are with the light switch. The switch could be bad. But, pull the lens, pull the bulbs, look for a screw or two. remove them if they are there. Some don't have screws and just pop into the headliner. Remove the light holder. On the back side is where the wires usually burn.
Jan 06, 2015 | 1999 Dodge Neon
Check Engine light with code P0703
About $20 for a new brake light switch that can be installed in about 15 minutes or less usually, may be good insurance for a long distance drive. The code doesn't say it's a switch malfunction, the computer has seen a fault in the brake switch circuit and set the code-could just be a poor connection there.
More important, how do the brake lights work? I think I'd buy the switch or check the connector by the pedal at least. The computer may not let the cruise control work because of the code.
Jul 14, 2012 | 2003 Dodge Neon
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Jun 26, 2011 | 1999 Chevrolet Venture
Starting problem - 1999 Dodge Neon
ask the car mechanic expert
Oct 29, 2009 | 1999 Dodge Neon
2000 neon air bags
Might be a loose wire inside the steering wheel at the airbag. Be careful around it, it might decide to clobber you. Good luck.
Sep 03, 2009 | 2000 Dodge Neon
1999 dodge neon
there is a fuse for the cruise control in the fuse box under the hood located right behind the battery. if the fuse is fine, then one of the cruise control components might be bad.
as for the headlight, you might need a new headlight socket. they are easy to replace and the replacement sockets can even be bought at walmart.
if the socket doesnt fix your problem, then you might need a new bright light switch
Jul 14, 2008 | 1999 Dodge Neon
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
