Question about Tablets & eReaders
Tablet not connecting to Wi-Fi; router is NETGEAR WNR 1000
Tablet is ematic EM63BL Error message is "Authentication problem" Router is NETGEAR WNR 1000
    Master:
  • 397 Answers
Try changing your wireless encryption settings, the type of security it uses can sometimes be an issue.
Here is a detailed guide on how to access your routers settings: Netgear WNR1000 wireless settings guide
Posted on Mar 26, 2014
Wi-Fi states authentication problem but can't reconnect and it won't give me the chance to input password
delete/forget the wifi connection in the tablet. re do the wifi set up with the proper WEP/WPA password from the router.
Apr 18, 2015 | Proscan 7-Inch Android Internet Tablet,...
My polaroid tablet model a7 will not authenticate and allow me to go on internet using wi-fi
Try it with a different router. Use a friends. Your router may have to be adjusted.
Go on the manufacturers web site and see if your problem is listed.
Jan 08, 2015 | Polaroid Tablets & eReaders
I can't get no is 9" tablet to work on WiFi. It connects and says connected but won't pull up authentication screen to sign on to network so I'm not able to fully use internet
try turning the wi fi off on the tablet and then turn the wi fi back on and try to reconnect.
you may need to set up the encryption. It could be set on WPA2 and the tablet may not cope with WPA2 may need to use WPA1 on router .
Jan 04, 2015 | Tablets & eReaders
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
Why won't my Ematic tablet load?
This needs a factory servicing as the main borad has been compromised.
Jun 28, 2014 | Ematic EM63BL - 7-Inch 4GB HD Tablet...
Cant connect to internet
Well, I may be an 18 yr. old and I may be no wiz but I'm big into computers and there are several solutions to this. 1) If there is a password put in the wi-fi, you need to: have a device in which will be able to put in the type of security and/or put in the EXACT password. 2) Make sure it is YOUR wi-fi you're trying to connect to. And 3) If 1 and 2 don't work, contact the company of which your wi-fi was bought from. I hope this explaination was helpful for your problem.
Mar 26, 2014 | Ematic 7" Tablet Computer
Authenicating problem on funtab pro
"Authentication Error" usually means when you are clicking on the desired wi-fi network and putting in your password you are making a small error in the password. ChecK:
a - You are putting in the correct CaSe. Most are CaSe SpEcIfIc so if it asks for "F" it means "F" and not "f";
b - You are not leaving any spaces before or after the password (some tablets especially seem to leave spaces.)
c - You are possibly putting in the Router Password. This is useless! you need to out in your Wireless Network KEY.
It came with your ISP letter or on a little card or is printed on the router
in the form of:
Name (SSID) Goodwombat45837
Key: HG56TY78JK88
You would type in HG56TY78JK88
Note hg56ty78jk88 would FAIL, you have put in lower case.
Hope this helps a bit.
Jan 20, 2014 | Ematic FunTab Pro with WiFi 7" Touchscreen...
I have an Arnova 9G2 tablet and a Netgear WNDR3300 wireless router. How do I add the wi fi network to the tablet? I donot have any SSID for the router.....
Without the SSID, you can't add the Arnova tablet to that network. The default SSID for the WNDR3300 is NETGEAR. You'll need to log into the router (preferably with a device on the wired network ports). Make sure that the wireless network is on and broadcasting its SSID for the 2.4GHz network. Confirm the password (passkey) and the encryption protocol. (The default user name and password for the router is in the manual, see page 19 (page 23 on the PDF) of http://www.downloads.netgear.com/files/GDC/WNDR3300V1/WNDR3300_SM_12Nov07.pdf . )
The tablet will look for available networks after you go to the Settings menu on the Home screen. Go to the Wireless & Network. Then turn on the Wi-fi (if needed) and then go to Wi-fi settings. Then find the SSID and enter the password and encryption type.
I hope this helps.
Sep 23, 2013 | Tablets & eReaders
My SVP tablet (Model TPC0902) will not connect to my home WIFI. I keep getting this message "authentication problem." How do I fix this? (All my other devices connect just fine)
Tablet worked fine on wireless for first two weeks. Now it's showing a line flickering in the wi-fi icon. I checked Ethernet and reset router button. Nothing.
Aug 11, 2013 | Tablets & eReaders
Tablets & eReaders Logo
197 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
