Question about Electrical Supplies
1999 Dodge Neon- headlights and dash lights all go out at bumps
Must push in and pull out dimmer switch to get lights back on
  • 76 Answers
Your dimmer has bad contacts, you can try to clean up the contacts or replace it.
Posted on Mar 26, 2014
Testimonial: "Do you mean the wiring plug contacts, or the interior contacts? How do I remove the switch? Thanks- Mike"
  • Larry Symms Mar 26, 2014
    could be either of those. You'll have to take the dash apart to get to it either way. Search youtube for videos on dissembling the dash or replacing the instrument cluster.
Why won't the dash lights come on
A number of reasons that dash lights will not come on. Let us start with the first. Do the parking lights come on on the outside of the vehicle when turning the switch on? If so, then I would suspect that you most likely have a bad dimmer switch. That is the switch that dims the dash lights. They commonly go out.
If the parking lights are not on then I would suspect a parking light fuse. If parking light fuse is good then I would suspect a headlight switch.
Most likely, based on experience with Neons, it is usually the dimmer switch. You can buy a dimmer switch on the internet or at your local auto parts store for a relatively decent price.
Hope this helps.
Mar 06, 2016 | 1996 Dodge Neon
Dodge 1999 neon headlight broken something is broken
dont tack it back cause they will say that you broke it and you fixed it. just try and replace the light housing and your plug
Jan 18, 2014 | 1999 Dodge Neon
Headlight switch
Pulling back on the dimmer switch is using the "flash to pass" feature common on most cars and trucks. You are putting power to the high beam circuit without using the headlight switch.
You would need to check for power in and out of the headlight switch for the headlight circuit, and then the dimmer switch. On models built after 1996 the headlight switch grounds the lights.
Apr 24, 2013 | 1999 Dodge Ram
Dodge ram headlights wont work unless dimmer switch pushed
Could be the headlight switch or the dimmer switch.
I would check for voltage at the dimmer switch first.
Sep 17, 2012 | Dodge Cars & Trucks
When I pull the headlight switch out why don't my
This is very common. the headlight switch is bad. replace the switch and that should solve the problem.
i have run into some that the dash lights dont work at all or they come on and off while driving.
the switch goes bad. there is also a dimmer switch . the dimmer switch controls the dim or brightness off the lights.
Mar 04, 2012 | 1998 Dodge Dakota
I have a 1984 dodge 4x4 1/2 ton. the headlights dont work just the running lights work when i pull the light switch out. i bought new headlights nothing
some times when the dimmer switch on the floor goes bad the headlights will cut out. Try replacing the dimmer switch and the headlights should come back on. My 84 dodge had that exact problem.
Nov 21, 2010 | 1984 Dodge Pickup 4WD
Interior light is stuck on, I have knocked something its not a fault I just cant remember how to switch it off again
if your neon doesn't have a direct switch on the side of it or if you cant push in on the light directly, check your dash for a gauge dimmer control switch. It is probably turned all the way up and in the clicked on position. Its usually located on the drivers side near the headlight switch if your headlights aren't activated by the armetuer on the column.
May 17, 2010 | 2006 Chrysler Neon
I have a 04 Toyota Tacoma. I have short in the dimmer switch.
It cold just be a fuse that is loose in the fuse box causing the dash lights to come on and off. Or potentially a loose wire from the fuse box the dash lights.
Oct 07, 2009 | 2001 Toyota Corolla
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
