Question about Polaris Pb4 - 60 Booster Pump
I have a new polaris pb4-60 booster pump and the seal went out, everywhere I have gone says a 1000 seal, but it isn't, have they changed to a new one?
I have a two month old polaris pb4-60 polaris booster pump, everywhere I have check and gone too says a 1000 seal, but it isn't, even in the Optimus book even says 1000. Have they changed to a new seal? If so what is it?
  • 1,631 Answers
PS-4280 is the new Seal or the direct replacement by Jandy #R0479400
Makup is Viton, which is much more durable. the 1000 has proven to be problematic.
Posted on Mar 17, 2015
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Posted on Apr 29, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Posted on Aug 24, 2009
Coastsider
  • 331 Answers
SOURCE: Just bought a new polaris booster pump (PB4-60)
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Posted on Apr 14, 2010
  • 990 Answers
SOURCE: I recently replaced the impeller shaft seal due to
Check your finger screen inside the wall fitting where your hose hooks up. Also check the impeller to be sure nothing is inside the vanes.
Posted on Jul 19, 2010
john224
  • 1378 Answers
SOURCE: I am having difficulty removing
For an impeller really stuck on the motor shaft you need to pull the motor thru-bolts and remove the rotor with the pump still attached from the stator. Lock the rotor in a vice and turn the impeller off with a large set of channel locks or a large strap wrench.
John
Posted on Nov 08, 2010
Seal for new polaris booster pump
You're looking for US Seal number PS 4280, Also Jandy # R0479400. The 1000 seal has killed more pumps than can be counted.
Mar 26, 2014 | Polaris Pb4 - 60 Booster Pump
Changed the seal in booster pump and now makes a rubbing sound
sounds like something on crooked try again take your time
Aug 28, 2013 | Polaris Pb4 - 60 Booster Pump
My polaris booster pump noise
bad motor due to bad seals leaking on motor better to replace whole pump next time
Jun 03, 2012 | Polaris Pb4 - 60 Booster Pump
I have new impeller & seals for pb4-60 booster pump and need to know the orientation of ceramic/rubber seal should be inserted into impeller - rubber lip toward or away from threaded brass wijidigit?
Rubber toward the impeller,so when you screw the impeller back on the ceramic ant the graphite on the other half face each other. This is so the graphite wears smooth against the ceramic.
Nov 13, 2010 | Polaris Pb4 - 60 Booster Pump
How do you change the shaft seal on a polaris pb4-60 pump?
BE CAREFUL YOU CAN BREAK THE SEAL PLATE BY OVER INSTALLING THE #1000 SEAL , TAKE 6 BOLTS OUT UNSCREW IMPELLER THE TAKE THE 4 BOLTS THAT HOLD THE SEAL PLATE TO THE MOTOR, KNOCK OUT OLD SEAL FROM SEAL PLATE USE SOCKET THAT FIT OVER SEAL. I USE A 1 1/4 SOCKET. THEN REPLACE CERAMIC IN IMPELLER (READ INSTRUCTIONS WITH SEAL) OR TAKE IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. HAVE HIM DO IT . $ AROUND 40.00
May 24, 2010 | Polaris Pb4 - 60 Booster Pump
Once the booster pump (for polaris 280) is turned on, water starts to leak badly from the front.
There is a bad seal and/or gasket in the pump allowing it to leak. It is usally the seal. Take it to a local electric motor or pump shop and the repair is probably under $50 total. You could also buy the parts to try it yourself, but the seal that pump takes (AS-1000) is a little tricky to seat properly. Besides, if your bearings are also damaged, the shop could fix that as well.
Oct 03, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Leaking from pump, is it usually the o-ring or something else?
Replacing the entire pump for a broken / leaky seal is a bit overkill - kinda like being advised to replace an engine when its your oil filter seal leaking. Poolcenter.com sells a Polaris "Go Kit" consisting of the three primary o-rings/seals that need periodic replacement as they dry-out and crack, promoting leaks, during non-operating months. Its called the Go-Kit 71 (for about $15.00) plus shipping. Replacement is fairly straight-forward if you know how to disassemble the pump - not rocket science but definately engineering.
Jun 29, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
156 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
