Question about Miele Dishwashers
Miele G2120 Dishwasher 5 yrs old stopped working
After pressing the on button to start the dishwasher I hear turning noises. The machine starts, then suddenly (approx. 1 min) stops and the 3 yellow LEDs for rinse/dry/end all begin to blink and the machine completed shuts down. When I open the door there is no water at the base of pan. I suspect no water is filling. I've reviewed the manual and cleaned the tri-filter and cleaned the non-return valve and reset the electronics. However, the problem still persists. I will review the water intake solenoid and also the overflow float switch, B8/3. I wonder if I am wasting time with the intake solenoid, I live in a big city with no water issues. To verify if the overflow float switch is damaged is difficult. Should I call a tech or continue to try? Have I missed anything?
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
  • 11 Answers
SOURCE: Item: Whirlpool Ultra Dishwasher Age: 3 yrs
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Posted on Oct 30, 2009
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
I have a Miele G640, the drain pump continues working even when I put the program on off.
Hi - theres a water leak to the base of the diswasher which causes the pump to run continously, you will need to determine its origin to minimize this from reoccurring.
Best way is to pull the machine out so you can tilt it backwards slightly to remove the acess panels either the bottom plate or an access panel in the front bottom of the machine to see where the leak maybe.
Aug 17, 2011 | Miele Inspira Series Dishwasher w/ 6...
After pressing start programme light goes off and it 'bleeps' all the time
I had a somewhat similar problem on my Miele G896SCI dishwasher. Here was the fix that worked, provided by phone by Miele.
1. Turn on at On/Off button. 2. Press and hold Start/Stop button until the red light blinks. 3. Press On/Off button to Off, then back On.
That reset the machine and it returned to normal operation for years
Apr 09, 2011 | Miele 24 in. G686SCi Plus Built-in...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele Dishwasher does not start
hi,
F51 fault is more than likely the heater relay is faulty but it could be your circulation pump is jammed up. if you are confident you can easily replace the replace the relay if it is faulty. you would need to put a meter across the terminals. if it is ok then the pump is blocked. if you are not confident you would require a service call. Miele have there own deadicated service team if you live in a metro area
hope this helps.
Mar 30, 2010 | Miele G892SC SS Dishwasher
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
Washer won't start
Called Miele customer service and local authorized Miele repair & pretty much determined control panel has conked out. Replacement part is $500 + @ $100+ more for service call/repair. OUCH! Washer is 7 yrs old and this is the first breakdown. Looks fatal...
Jul 09, 2008 | Miele G848I Dishwasher
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
