Question about Hotpoint Ultima WF860 Front Load Washer
F10 error code comes up really loud banging and shaking
Error code f10
My ford explorer 2004 makes a loud banging noise while turning and the 4X4 high light flashes on and off as well as ABS light stays on
One loud bang is usually a ball joint. Jack up one side of car and shake tire to see what is loose. Shake each steering component while the side is lifted. Do both sides of car.
Dec 30, 2013 | 2004 Ford Explorer
Loud noise during spin cycle
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Sep 06, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 starts then turns off or shake/bangs off w/error HL1
the heater is plump correctly?if yes assembly valve need replacement, if you by pass before dirt may be inside.
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Gold Fridge w/ freezer on top. LOUD banging noises.
I think the banging means the compressor is shot. (more like a load "clunk"). I had the same noise on a dehumifier.) I dont' think replacing a compressor is a DIY, and doubt it is economically efficient. But I leave that to the specialists to comment on. Check Craig's List in your area - you can get a good deal for a few hundred bucks.
Also, the "clanging noices" is probably the fan blades for the air circulator that moves cold air from the freezer to refrig compartment. Check the online manual for your model (exploded parts view) to see where it is located and if it is readily accessible by taking out a few screws inside the refrigerator. Might be more than one fan - open the door when it happens and see if you can locate where the noice is coming from. This is a plausible DIY - I did it only my old fridge - replacement parts were cheap. But you might even be able to just reallign the fan blades so they don't clang.
Oct 26, 2008 | Refrigerators
Samsung SCX-4216F - loud banging noise
the doctor blade in the cartridge tobe replaced.
Jun 18, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Hotpoint Ultima WF860 Front Load Washer Logo
19 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
