Question about HP LaserJet 4350 Printer
Hp 4350 envelopes are blank
HP LaserJet 3050 All-In-One Printer blank pages after attempting to print second envelope from same document - turning off and back on solves temporarily
If the same fault occurs with different printers it is almost certainly caused by the document.
"...second envelope from same document" suggests you are using a mail-merger. Is that right?
What happens if you start again from scratch? Mke a new document and try to print it a a single entity, without using mail merge?
Feb 05, 2016 | HP LaserJet 3050 All-In-One Printer
Envelopes print blank
are you using the manual feed tray? If not try that as a solution.
Mar 26, 2014 | HP LaserJet 4350 Printer
I can't get envelopes to print at all from word to my HP4350, I have reset printer to envelope mode on tray 1 and still nothing. The printer says no jobs are pending. The two are not "talking" t
There may be a problem with the print driver. Try deleting the printer from your computer and then re-adding it. Print driver can be downloaded at www.hp.com. in case you have lost your installation CD. Good luck !
Apr 15, 2013 | HP LaserJet 4350 Printer
4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
Nov 25, 2009 | HP LaserJet 4350 Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Mar 20, 2008 | HP LaserJet 4350 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HP laserjet 4250 evelope smudge
I think it's been left open and has collected some fluff and dust, It needs a good clean. Just maybe there's a Toner Printer Cartridge leak.
Feb 05, 2008 | HP DeskJet 5650 InkJet Printer
Blank print out
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Jan 29, 2007 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
