Question about Dewalt Tools Generators DG2900 , 2900 Watt Gas Generator
No engine speed change under load - Dewalt Tools Generators DG2900 , 2900 Watt Gas Generator
    Sergeant:
  • 259 Answers
Sounds like the governor is not adjusted right or is broken internally. With the engine off make sure the throttle in the carburetor is full speed and unloosen the bolt that holds the governor arm on the shaft and make sure the shaft is turned the same way the carburetor linkage moves to full speed and tighten the bolt.
Posted on Jun 27, 2014
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
Jul 03, 2014 | Ingersoll Rand Electrical Supplies
2006 turbo diesel landcruiser trayback surges when engine is under load
possible air still in the pump so bleed at the pump
Feb 03, 2018 | Cars & Trucks
I have a 1997 lumina with 3.1L. the problem started with loss of power under load and p0300 code. check coils and vacuum leaks both OK.change spark plugs and wires.[same problem] check compression OK.
Since you changed the sensor we will assume it is working. When you disconnect it you put the computer in limp mode which stops it from using sensor values. If code 300 is the only code we will assume the coolant temp sensor and others are ok.
I would check fuel pressure with a gauge next.
Aug 21, 2012 | 1997 Chevrolet Lumina
Missing
It could by the spark plugs. I used different types but when I changed to AC Delco the problem stopped.
Feb 01, 2012 | 2006 Chevrolet Colorado
21 hp kawasaki stalls and floods carb when put under load new plugs, new filters, oil change, new coils new $400 carb what can it be ????
Seems odd that after changing carbs you have this symptom but a dirty air cleaner or restiction in the air intake ducting can cause this. I note you said you changed the air filter(s). I am assuming you changed both the paper and foam filters. My thoughts are maybe there is some gasket material partially blocking the intake under the carb so when under load it is acting like the Choke is on. ( Before you go lifting off the carb.. a partially engaged choke valve will do the same thing. It will run just fine at low speeds or little load but when you put a heavy load it will choke out / get too much fuel.
Last thing that can cause the engine to act really weird is that the gas cap is vented and if the vent is clogged in the gas cap it will cause very unstable operation of the engine at higher rpms.
Your engine service manual is here:
http://www.smallenginewarehouse.com/images/manuals/FH641-Service.pdf
Carb informationis in section 2 - 8
I reommend you inspect
- the tank cap (no plastic bag in place of the rubber under the gas cap to prevent the tank from leaking)
- the choke linkage and position of choke valve (Off or partially on?)
- screen if any under the air filter (Thinking out of the box... what if the air filter is being drawn against the air cleaner / filter housing causing a choke situation under load)
Don't do this for very long but try a high load test with the air filters removed.
One last dumb thought is... the fuel pump is ported to the engine crank case breather. If the diaphragm fails it can put fuel in the oil which will cause the oil level to rise due to the added gas and then end up over pressurizing the crank case. (You said you changed the oil.. and I would think the oil level is still the same as it was post oil change.)
Those are my thoughts and recommendations for the moment. If anything else come to mind I will send you another post.
If you have questions feel free to ask. I wll tell you that I am using the service manual and my 40 + years of experience to help you.
Thanks for choosing FixYa,
Kelly
Mar 28, 2011 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
I have a coleman 6000. It runs for a whileand when I load it up it trips off.
Make sure the governor is working properly. When you put a load on it the engine should increase in speed slightly. Make sure the engine is running at the correct speed 3600 rpm. Try plugging in an item that draws less power such as a electric drill and see how the generator behaves. Also make sure the engine runs smooth while not under any load. Check the voltage from the outlet to make sure it is putting out 132 volts not under load.
Mar 14, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
Starts but quits under load
If it won't pull under load it usually means it's sucking air somewhere. Let it idle and spray around the intake with wd-40 untill you find the leak ( the engine will speed up when you do ) .
Sep 26, 2009 | 2006 TN'G Baja 150
1999 Dodge Ram 5.9L 4X4 not enough fuel
check the fuel filter and the EGR valve
May 07, 2009 | 1999 Dodge Ram
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Dewalt Tools Generators DG2900 , 2900 Watt Gas Generator Logo
63 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
