Question about Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3
Problem with blingking
I remove the battery to reset but comes out with EOL
How do I turn off eol on my tag
"EOL" means "End of Life." The battery needs to be replaced soon. I agree with other post. . . if you had the battery replaced recently, it was bad. I have had my Tag Kirium Formula One for 12 years and have only replaced the battery once.
May 10, 2014 | Tag Heuer Kirium Formula 1 Chronograph...
Tag kirium has the eol flashing error even after a new battery was installed
Don't assume the battery you installed is good. Check it or replace with another.
Dec 09, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
Hi i have a t-touch and i saw that the battery is Q/eol (end of life)...what do they want to say with it? If the battery dies the watch does too?
mcdevito75 here, I doubt very much it means end of life, unless it is actaully written on the watch or battery, Most Battery watches have access to change a dead battery, BUT!! there are sealed case battery watches too, these kind you find in vending machines, at McDonalds as giveaways etc.
Jun 24, 2010 | Watches
What does the flashing EOL mean?
EOL is short for End of Life. Don't worry. According to TAG, that just means you need to replace in the internal lithium battery.
Jan 17, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Jan 04, 2010 | Wittnauer Laureate 12R12 Wrist Watch
Second hand skips
This is warning: it's time to change the battery. Your watch is fitted with EOL (end of life) feature and this is how the low battery power is displayed. However, the watch will keep running correctly for about two weeks.
Rate me, please.
Jul 30, 2009 | Tag Heuer Watches
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
Flashing digital display
I just managed to solve this problem. Turn the digital face to the first screen which is probably flashing EOL with date. Then pull knob out as if you were going to set the time. Hold in two auxilliary buttons, you should see BAT come up on the screen. That should be it stopped flashing!
Dec 25, 2008 | Tag Heuer Kirium Formula 1 Chronograph...
Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3 Logo
35 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
