Question about Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3
Remove the battery then put comes out EOL
Before time is blinking and did not stop blinking, I decided to remove the battery then put it back then comes out the EOL
How do I turn off eol on my tag
"EOL" means "End of Life." The battery needs to be replaced soon. I agree with other post. . . if you had the battery replaced recently, it was bad. I have had my Tag Kirium Formula One for 12 years and have only replaced the battery once.
May 10, 2014 | Tag Heuer Kirium Formula 1 Chronograph...
I have a Steinhausen TW524L Watch how do i change the battery or is this watch automatic it has stopped running.
It's not as easy as popping off the back like some watches to replace the battery. The 4 screws on the top bezel are not the ones to remove. Look at the back side of the watch and you'll see 4 really tiny pinholes. You'll need a jewelers screwdriver small enough to fit into the holes to remove the 4 screws. Once you do that, the two halves of the watch come apart with a little pressure. It takes a little prying to get the case to separate. Once you do that, you'll see the battery. Be careful with the waterproof gasket as you'll need to put that back in the same position to keep the case sealed. The gasket is really delicate. You might consider taking it to a watch maker to change out the battery if you don't have the tiny (and I mean really tiny) screwdriver to remove the 4 back screws.
Nov 12, 2011 | Watches
What does the flashing EOL mean?
EOL is short for End of Life. Don't worry. According to TAG, that just means you need to replace in the internal lithium battery.
Jan 17, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Jan 04, 2010 | Wittnauer Laureate 12R12 Wrist Watch
Second hand skips
This is warning: it's time to change the battery. Your watch is fitted with EOL (end of life) feature and this is how the low battery power is displayed. However, the watch will keep running correctly for about two weeks.
Rate me, please.
Jul 30, 2009 | Tag Heuer Watches
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
My tag heuer aquaracer has a problem: the second hand stops and then speeds up really quickly for about 5 seconds. any idea why/how to fix it?
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Mar 11, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Problems with Tag Heuer 2000 Classic WK1120.BB0314
Explanation is simple: your watch has jammed geartrain or some dirt particles stuck into geartrain. This is why the seconds hand was moving backwards and forwards.
Nothing to do with EOL (End Of Life) feature wich is built into watch microelectronics and signals that this is the time to replace battery by advancing seconds hand two or four seconds at once.
To open the watch you need a proper watch caseback opening tool, but I can't see any reason for doing that as you will not be able to fix the geartrain problem without proper knowledge and skills.
If the warranty of the watch is expired, you don't need a TAG specialist as you will be charged for job anyway. So, find your nearest watchmaker shop and ask for repair.
Feb 14, 2009 | Tag Heuer WK1120.BB0314 Wristwatch
Flashing digital display
I just managed to solve this problem. Turn the digital face to the first screen which is probably flashing EOL with date. Then pull knob out as if you were going to set the time. Hold in two auxilliary buttons, you should see BAT come up on the screen. That should be it stopped flashing!
Dec 25, 2008 | Tag Heuer Kirium Formula 1 Chronograph...
Swatch Watch, Unisex Swiss Digital Touch Screen Black Silicone Strap 3 Logo
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
