Question about Kenmore Sewing Machines
Model 385 16765
Presserfoot will not stay up
  • 72 Answers
Does the presser foot lift up when you use the lever? Can you open the face cover plate and see the presser foot lever to see if it is connected and functional or has it become disconnected?
Posted on Mar 28, 2014
Bobbin stuck
Please first remove the first needle and presserfoot. After If you're experienced with sewing on a sewing machine, don't be afraid to make changes to your bobbin tension and bobbin case. Or you gone to mechanic shop. Then you will buy a check correct case size bobbin.
Dec 19, 2013 | White Sewing 2037 Mechanical Sewing...
Question about a bobbin
First you have to determine if the thread under the plate is the bobbin's thread... or just great loops from the upper thread.
Bobbin snarls are caused by the bobbin unspooling in the wrong direction.
Burrs and snags on the carrier.
Upper thread snarls in the bobbin area are "operator error" Typically, upper thread not threaded correctly (foot UP, buttercup)... or neglecting to put the presserfoot down while sewing.
Good luck.
Nov 16, 2012 | Brother Sewing Machines
Euro pro sewing machine manual
see if this is the right manual for your machine, just click on the link
http://www.sharkclean.com/manual/377-374-373-372-372H_ENG_REV_0504A.pdf
if it's not the one you need just send me a comment and I'll try to find you
another one.
Oct 19, 2012 | Sewing Machines
Machine is powered on. When I press the presserfoot there is no sewing action. The machine emits a soft beep as long as I hold down the presserfoot.
hi, it could be several things
MACHINE DOES NOT RUN
1.the motor belt is probably broken
2.the motor belt may be loose-needs to be serviced
MOTOR DOES NOT RUN
1.the electrical cord may be defective-replace
2.the motor maybe burned out-smell the motor to see if it smells like a dirty pair of socks, if the motor smells it needs to be repalced
3.the foot pedal may be defective-replace
Sep 09, 2011 | Singer Confidence 7463 Computerized Sewing...
Flashing lights/ no functioning of machine
When we had the same problem as you, we called the helpline and they walked us through the basic reset process. We turned it on and had the same problem. We then raised the presserfoot, turned the wheel on the side of the machine, put down the presserfoot, and then unplugged the power cord from the side of the machine. We then turned it on, and it was fixed! Hope this helps!
Jan 02, 2010 | Singer Sewing Machines
Needle alignment on serger model L5
Presserfoot properly secured to the machine? Happens to one of the ones I own if I don't get it quite clipped in properly and then lower the presser foot. In any case, when you figure out the issue, throw out those needles.... they're damaged, and possibly bent and will only give you further grief.
Aug 15, 2008 | Elna Sewing Machines
Big loops on bottom stitch
You have no top tension. Rethread the top of the machine. Make shure you raise the presserfoot before threading.
Feb 23, 2008 | Singer 6038 Mechanical Sewing Machine
Kenmore 12110
lack of top tension. Raise presserfoot and rethread the top of the machine. Allso check for a bur on the hook.
Dec 10, 2007 | Singer 8280 Mechanical Sewing Machine
Brother vx1120 machine bobbin jam
Rethread the whole machine. Make shure you raise the presserfoot before threading.
Nov 30, 2007 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
44 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
