Question about Sony Handycam Video Cameras
Sony handycam not responding the green light flash
Sony sxrd 60 is not comming on the green light in power button turns red and flashes 4 times repeatedly. Does that mean it's a bad projection bulb? Model # KIDS R60XBR2
You have a bad fan. 4 blinks is a stuck or non responding fan. Check the one on the back near the lamp to see if its moving or not.
Aug 15, 2016 | Sony Televison & Video
My sony digital handycam flashes C:31:42
C:31:42 indicates that you having a problem with capstan motor. It has to be replaced.
Nov 05, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Still flash
Sorry, no light, no flash! It IS, however, compatible with the Sony HVL-HFL1 Combination Light and Flash unit - MSRP $149.99, but it's online for as cheap as $106 through Amazon. Flash range is 5m, and it's powered off the camera battery, so there's no in-flash battery to worry about...
Please rate this solution if you found it helpful!! Thanks, and good luck!!
May 12, 2009 | Sony Handycam® DCRSR45 HDD Camcorder
Not able find the exact one. Adobe flash player is not suiting this handycam
    Please install Acrobate reader on you pc that has also FLASH PLAYER  or from below link you cam easily cohice any flash player which fulfill your requirment.The link is given below :
www.download.com
Thanks for using fixya.
May 10, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Touch Screen not responding to Touch
Connecting wire/ cable between LCD and Main Board is broken/ cracked and needs to be replace. Contact nearest Sony Service Center for proper repair.
Jul 19, 2008 | Video Cameras
Flashing lights
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Feb 17, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Camcorder not working
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Oct 27, 2007 | Sony Handycam DCR-TRV250E Digital...
the flexwire cable is have an openline and that line is connected to the touch screen panel...it have to repaired or replace that flexwire to the service center....in our shop we modified that wire and became more durable than the original wire......:-)
Jun 05, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Video Cameras Logo
16 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
