Question about Kid Designs Kiddesigns Be637 Barbie Rock Star Guitar
Be637 guitar won't turn on
I can't get it to do anything. New Batteries. I took it apart and only found the mic input broke. could this be the problem?
A few days ago, the batteries in my Rock Band 2 guitar died so I replaced them with new ones. When I tried to turn the guitar back on it wouldn't work. When I hold down the Xbox button all of the...
Yes, it's called dead batteries.
Replace the batteries with new ones, and then just turn it on. It shouldn't be necessary to sync it to the xbox, unless yuo have synced it to another xbox lately.
Jan 11, 2013 | Video Game Consoles & Games
When I set the effects to the channel for the mic, It kills mic volume
Check your mic input settings, click the "VOLUME" control (and/or sounds fron control panel)... also check and PLAY with "GAIN +20" on the settings..
Write me back on your results..and tell me your OS... question was vague..hope it helped.
Oct 18, 2012 | Tascam DP-02 8-Track Digital Recorder
My amp makes a loud foghorn type noise whenever turned on. Even if i have the volume turned all the way down and the guitar unplugged it still hums. I'm not sure if its an amp or speaker prolem. I took...
Likelly the TDA7293 chip in the power amp has failed. It shorts to one power rail and drags the power down where it hums... this CAN damage the speaker if left on. Verify the problem and replace the chip. Slight chance there are bad electrolytic filter caps but those are easily spotted.
Aug 06, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have a Bose surround sound system. The remote is a model RC28T1-27. It won't do anything, turn on or off, volume, select source/input etc. I have tried several new batteries but nothing. Any ideas?
I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose
The problem is that the broadcasting antenna at the top of the remote is very a very thin wire wrapped around a heavy cylindrical magnet and its solder points are extremely weak. You most likely dropped it and it came loose. I re-soldered mine and it worked perfectly.... until it broke again. The leads are very small and hard to fix.
Chalk it up to poor design.
Jan 13, 2011 | Bose Televison & Video
Sync light on guitar wont blink anymore
hey , i think the wires inside might have came lose , my whammy bar broke an when i took it apart i noticed the wires arent they sturdy , so just pop a few screws an check it out
May 13, 2009 | Nyko & FrontMan Wireless Guitar Controller...
Digitech Vocalist Live 4 blead through
You need a directional microphone, and then it needs to be pointed away from the guitar. Another technique would be to provide some acoustic insulation between the mic and the guitar, like a wall or a partition like what is used to set up office cubicles.
Feb 23, 2009 | Digi-Tech Digitech Vocalist Live 4...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Im using a mic, but its looking for a guitar, how do I get it to find my mic
It shows a guitar for higher input level or you can set it to a lower level(more sensitive) - it will then show a microphone
Dec 21, 2007 | ElectroVoice RE2-410 Professional...
Problem with guitar
1.make sure the guitar/mic switch is pointed to the guitar side. increase the guitar/mic level. increase the output level. 2.another thing you can do is check the "sound and audio devices" to see if everything is set to Edirol UA-4FX. If everything isnt, fix it so that it does. and remember to disable your computers stock sound card. Edirol UA-4FX is your new sound card from now on. 3. if thats not the case, try reinstalling the drivers. 4. If all of the above fail, you probably have a loose connection/ bad wiring in the guitar/mic 1/4" input. you can choose to open up the device and solder that yourself and possibly lose your warranty or have the entire unit replaced. Hope I helped! good luck!
Apr 30, 2007 | Edirol UA-4FX External Sound System
Kid Designs Kiddesigns Be637 Barbie Rock Star Guitar Logo
Top Kid Designs Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kid Designs Toy Expert? Answer questions, earn points and help others
