Question about Hitachi Drills
I NEED THIS PART HA13001, PWR AMP 1x17.5W 18V
  • 76 Answers
Http://www.amazon.com/HA13001-Power-AMP-1x17-5W-18V/dp/B00EUBHERM
Posted on Mar 26, 2014
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
Black & Decker 18V Cordless drill
Go to eReplacementparts.com. Enter the make and model number.
Sep 30, 2014 | Black & Decker 18V Cordless Drill/Driver
Beutler zte2s
Make sure you have 24 volts @ the transformer inside the furnace....If you are reading 18V across the Red & Common, try reading across R & anything else ie G, Y, W. If you have 24 volts there, then trace your common wire & make sure it is not splice somewhere in between the tstat & the furnace. If you have any unused wires, hook up the different color wire & make sure you use the same wire for common @ the furnace.
Nov 12, 2013 | Heating & Cooling
Need fuse box pannel to see what fuse is what
FUSE USAGE
1. 10 AMP LOW BEAM-LEFT
2. 10 AMP LOW BEAM-RIGHT
3. 30 AMP BRKR POWER WDO/SUNROOF
4. 30 AMP BRKR PWR ACSRY
5. 20 AMP BRKR LIGHNG CONTROL MODULE
6. 15 AMP IGN/REM ACSRY CONT/INST CSTR
7. 10 AMP SUPPLEMENTAL INFLATABLE RST
8. 20 AMP CORNERING LPS/TURN SIG
9. 10 AMP CRANK SIGNAL-SIR
10. 20 AMP TRK REL/FUEL FILL REL/BACK-UP LPS
11. 15 AMP BAT/RADIO/PWR ANT/CIG LGTR/ INST CSTR
12. 20 AMP ELECTRONIC LEVEL CONTROL
13. 20 AMP BRAKE & HAZARD LAMPS
14. 15 AMP PARK LAMPS
15. 15 AMP COURTESY LPS/PWR MIRRORS
16. 10 AMP COOLING FAN
17. 25 AMP HEATING/AIR CONDITIONING (C67)
18. 15 AMP A/C AUTOMATIC ELECTRONIC (CJ2)
19. 10 AMP ANTILOCK BRAKES
20. 10 AMP LOW COOLANT/LAMP MONITOR
21. 10 AMP IP LIGHTS
22. 10 AMP HI BEAM-RIGHT
23. 10 AMP HI BEAM-LEFT
24 10 AMP IGNITION/RADIO
25 25 AMP WIPER/WASHER
FOR ACCESS TO ADDITIONAL FUSES
REMOVE RIHT SOUND INSULATOR
May 16, 2009 | 1991 Buick Park Avenue
What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Mar 07, 2009 | Ryobi Multi-Volt Battery Charger
Diagram fuse inside car
Your fuse panel is located by the emergency brake.Depress the two tabs and the fuse box will swing down, the panel diagram is written on the panel door.
Jul 22, 2008 | 1992 Buick Park Avenue
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
Drills Logo
60 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
