Panasonic fax machine FX-F230 does not turn on
Dear Sir I own Panasonic fax machine for home use (model KX-F230), which I have been using it for so many years. So far I did not have any problem. But recently, I wanted to send fax and turned it on. But it failed to turn on, meaning there is no response- no display on the screen and no dialing tone. This time the machine was stored for long time. Just wondering what's wrong with the machines. Is there any rechargeable battery that has to be charged before it turns on. Or is there any other problem with it. Your advice would be very much appreciated. Adil Younis
  • Adil Younis
    Adil Younis Mar 26, 2014
    I tired all combinations but it did not turn on. Then I opened the bottom cover to see if there was any blow fuse etc. I noticed there is button battery CR2032. It does not say that it is chargeable. Just thinking, if the battery is in service for more than 10-13 years then problem could be that iit is completely discharged and needs to be replaced. Another question that comes to mind is what does this tiny battery has to do with the start up function. I am not expert on electronics but may be it has important function to complete the system. System thinking! intelligent. Any comment Sir?
3 Suggested Answers
  • 168 Answers
SOURCE: Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Posted on May 02, 2008
n25an
  • 622 Answers
SOURCE: Liquid crystal display on fax machine - does
your best bet is to go buy another one... for the cost of the display you could actually get a second hand machine that works better...
Posted on Dec 17, 2009
Panasonic call service 3 kx-mb773
sir i have panasonic fax kx-MB2030 it come call cervice3 error i try #9000*550 but it not work
Mar 12, 2013 | Panasonic KX-FL611 Plain Paper Laser Fax
I need drivers Panasonic KX-FLB758 for windows 7 please... thank I´m from Argentina
KX-FLB758 was apparently a clone of KX-FLB756 and KX-FLB751 model. Drivers available on the following page should work fine:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/Drivers-Downloads/model.KX-FLB756.D#ts
Aug 19, 2010 | Panasonic KX-FLB756 Plain Paper Laser Fax
Call service 3 panasonic kx-fl612
hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
Jun 24, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
Upgrade install to window XP,,??
my computer don,t detect panasonic fx-fm131 fax
Jul 15, 2009 | Panasonic KX-FM131 Fax
Panasonic fax KX-FT73
I THINK THAT IS MECHINACIAL PROBLEM .CHECK DEEPLY ALL SENSORS AND ALL GEARS .ANY MISHANDLING IN MACHANICAL.mian akhlaq
Aug 07, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Retrieve messages away from home on a Panasonic KX-FPG381
You have to set a polling number, you WILL need a manual. Use your keypad just enter this number when you phone home
Aug 12, 2007 | Panasonic KX-FPG381 Plain Paper Thermal...
jasbo
jasbo
