Presario f700 dvd drive not detected
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Check cables make sure that the red is on the one pin if ribbon if sata make sure in the right way
Posted on Mar 30, 2014
2 Suggested Answers
fixtor
  • 68 Answers
SOURCE: Compaq Presario F700 DVD problem. Today would not
Please perform the below steps to fix this issue.
1. Check in device manager for cd drive option. in case its visible, right click on it and uninstall it and reboot the system and the corect drivers should get loaded automatically.
(to go to device manager follow the below steps:
in XP---1.On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
2.In the System Properties window click the Hardware tab.
3.In the Hardware tab click the Device Manager button.
in vista\windows 7---1.Click on the Start Orb.
2.In the Start Search box type: device manager and then press enter.)
2. Delete the upper and lower filters:
For XP
Start -> Run ->regedit - > Ok
It opens the registry editor window. navigate as per the below path
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the right side pane if you see upper or lower filter options...right click and delete them.Restart the system
For Vista
Start - > Search - > regedit - > OK
3. Check in Sysem setup/BIOS and see it the drive is getting detected. in case the drive is not getting detected over there it is a possibility that the data cable that connects the drive to the main board might be loose. if that is the case we need to go into more detailed troubleshooting. please let me know if above steps fix the issue else will provide further steps.
regards.
Posted on Jan 07, 2010
My compaq presario f700 notebook will not detect my dvd/cd rewiter
try searching att hp support page
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=470024-192%20&search_searchtype=s-002
Sep 07, 2014 | Compaq Presario 700 470024-192 Notebook
My HP Presario F700 recently started showing a recource conflict on motherboard while starting up. In addition the DVD-drive is not recognized even it does a self test. Any idea?
there might be 2 problems that come first in mind
1: due to long time pc explotation bios battery died
2: bios reseted and all divices become masters
firs test battery voltage ir its good try to change bios boot up log
Jul 29, 2014 | HP Compaq Presario F500 F700 and G6000...
HI! MY NAME IS KEVIN, MY PRESARIO F700 JUST STOP WORKING THE LIGHT OF THE POWER BUTTON JUST KEEP FLASHING. WHAT DO I HAVE TO DO.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 26, 2011 | HP Compaq Presario F500 F700 and G6000...
My Presario F700 won't recognize it's dvd drive. IIt doesn't show in the boot options, so it would appear that the BIOS is not recognizing it. I have tried the drive in another laptop and the BIOS detects...
Try going into "control panel", find "device manager" and right click on it. In the list, find cd-dvd rom drivesand click on box at right side of line item. It should dop downand show your device. right click on it and you shoud see "enabe" or "disable". If it says enable, click on that.
Mar 15, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
My Dvd drive is not detected on my compaq presario f700
first check in device manager for dvd-drive if it not shown their .....then if u have idea about basic hardware remove the drive and fix..........otherwise call for technical expert
Nov 26, 2010 | Compaq Presario 700 470024-192 Notebook
For XP
For Vista
regards.
Jan 07, 2010 | HP Compaq Presario F500 F700 and G6000...
Presario F700 Cant Burn/Write
try reinstall it with old driver, first uninstall the updated driver, then install it again with old driver.
When it's OK, don't update the driver.
Dec 08, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
My Compac Presario F700 will not come up, I just get a blank screen even in safe mode. When I press F10 it runs through programs and stops at crcdisk.sys? How do I reset system?
If you have the software disks that came with the computer you can use those to restore the system. Or use the windows installation disc to repair/restore windows.
Jun 15, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
if u want Drivers for Compaq presario F700 please use below link for win vista Os ..there is all drivers for u r laptop
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=3629568&lang=en
If this link is useful for u please rate me...........
Jun 14, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
