Question about ZTE Score
My zte v987 shuts down and i cant open it anymore. When I tried pressing the power button, only the zte screen will flash then it will shut down again :(
  • Marie Terriz
    Marie Terriz Mar 27, 2014
    yup, the battery is new :(
    New Friend:
    Problem Solver:
  • 9 Answers
Did you ckeck the battery? Sometimes it's just an easy solution like that.
Posted on Mar 26, 2014
Ihave the ZTE 4g android phone well i was playing a game and my phone shut down then came back with a screen lock i don't have a password for how do i get it off i never lock my phone
  1. Back up data on the internal memory.
  2. Begin with the device turned off.
  3. First, press and hold just the Power key for 1-2 seconds, then quickly press and hold the Volume Up key as well.
  4. Continue to hold both buttons until the Select Boot Mode screen displays.
Tony
Feb 16, 2017 | ZTE Cell Phones
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
How do i unfreezekindlefire
Press and hold the power button for twenty seconds or so, ignoring the shut down prompt, until it turns off. Release the power button, then press and hold it again for two seconds or so until it starts to reboot.
Nov 12, 2014 | Amazon Kindle Fire HD
My htc one vx shut down and will not start it has a flashing orange light been charging for 24 hr
  1. While the phone is off, press and hold the VOLUME DOWN button, and then press and hold the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
  3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Jan 01, 2014 | HTC Cell Phones
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Turned on and screen went blank after posting ; "resuming windows"
Try holding down the power button to shut it down. Then press it again to reboot.
Aug 24, 2008 | HP Pavilion dv6000z Notebook
Can anyone help?
Sounds like your power supply may have died. Check all the power connections to your pc (if it is connected to a power-bar, make sure the power bar has not gone bad). If everything looks good there, you probably need to by a new PSU (Power Supply Unit)
Apr 06, 2008 | HP Compaq Presario V2000 Notebook
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Not powering off
lights flashing like that usually means something is wrong in the shut-down procedure. my guess (and is quite common ) is that the lens doesnt retrack all the way hitting a clitched gear spline or something, maybe just weak motor,....as your retry it it settles in proper and tells the micro its ok now to shut down. good luck
Sep 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
ZTE Score Logo
175 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
