Question about Sony KD-27FS170 27-Inch FD Trinitron WEGA Digital TV
Red light flashing 4 times
After turning on the tv the screen turns blue with Vertical lines running from side to side on the screen and the tv turns off and the red light flashes 4 times
  • 76 Answers
Sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Posted on Mar 26, 2014
Screen is not bright like in advertising photos and the there is a line on the screen shaped a bit like an S . Screen grey one side,black the other.
The watch is brand-new, and you have every reason to expect that it would appear and function correctly. Return the item and ask for refund or replacement.
Oct 10, 2016 | The Watches
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
    Dont have that particular watch, but see if this works.
    Setting the time on the PU910222003 Puma ladies watch.
    The process may be less complicated than you would think.
    First, a couple things you need to know and remember.
    1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
    2. Touch means you are touching the dial and the (stones or outer edge)
    To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
    Now you are ready to change stuff.
    Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
    While touching and holding the bottom of the dial you may see the back light turn on.
    That is actually how you do that.
    By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
    To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
    Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
    When you are done. Touch the bottom of the dial to exit this setting mode.
    Day to day use,
    Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
    While touching and holding the bottom of the dial you will see the back light turn on.
    Cool feature,
    This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
    Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
    I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
    Dont have that particular watch, but try this.
    The process is actually less complicated than you would think.
    To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
    Day to day use,
    Cool feature,
    Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
    Casio F91W-1 Wrist Watch- backlight color
    You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
    May 06, 2010 | Casio F91W-1 Wrist Watch
    HAI
    Start by going to a good college and studying electronics 101 followed by electronics 102, math, algbra, etc, until you get an engineering degree. Now as for the dark purple and blue. It sounds as though you have a picture tube getting weak in the red gun and unless you can turn the red gun up you may need a new set. Anyway, good luck and have a great week
    Ed
    NC Electronic
    MIlls Wyoming
    Jan 06, 2008 | St. Moritz Bellagio Flyback Chronograph...
    Sony KD-27FS170 27-Inch FD Trinitron WEGA Digital TV Logo
    94 people viewed this question
    Top Sony Watches Experts
    Lawrence Oravetz
     Mikey
    Mikey
    Emmanuel Sackitey
    Are you a Sony Watch Expert? Answer questions, earn points and help others
