Question about Evesham Computers & Internet
My Evesham want connect with my TV
I just have a question, if you could help me. I have a desktop at home but it dosnt seem to work with my tv or any of the moniters in the house. However on the odd occasion it will work. It checked the cable with my laptop works with that and the moniters and tv are working fine with my laptop. I have the feeling that the port on the desktop might be loss, but dosnt feel loss and no wires inside look out of place. If it is the port how would I repair it or is there another way I can connect my tv with desktop.
  • 2 more comments
  • Larry Symms Mar 26, 2014
    which port are you referring to (15-pin VGA, HDMI, or DVI)?
  • william taylor
    william taylor Mar 26, 2014
    15-pin VGA, running on windows xp
  • william taylor
    ow also the license for the windows says 2005 (using original windows) making desktop 9 years old, when i have TV on the screen say out of range or no signal. if any of that any help. i can find the model for desktop just the make
  • william taylor
    i dont have a manual as its second hand also i dont know what a PCI or AGP is, what sort of card are you on about. and if the video adapter is the cable that connects the screen and desktop i know that works. there is a similar port which is 15 pin but one port has 15 holes for the pins and the other has 15 pins.
  • 76 Answers
Most modern desktops have more than one video port and not all are active all the time. Try using the other ports. If that doesn't work you might have a bad video controller. You can buy a replacement video adapter which will plug into one of your PCI or AGP ports. Make sure you know without a doubt what ports your have free before buying a card there are a lot of different ports. The manual is your best bet for knowing for certain what types of ports you have.
Posted on Mar 26, 2014
Testimonial: "If the PCI card is the same as the graphics card then I know what I need to get. DOES THE CARD HAVE TO BE A SPECIFIC MAKE."
  • 35 more comments
    if you get no screen on startup on your VGA you have a bad adapter unless your bios offers the ability to turn it off (but you would have had to have done that manually)
  • william taylor
    i dont have a manual as its second hand also i dont know what a PCI or AGP is, what sort of card are you on about. and if the video adapter is the cable that connects the screen and desktop i know that works. there is a similar port which is 15 pin but one port has 15 holes for the pins and the other has 15 pins. and what the bios
  • william taylor
    desktop is 9 year old
  • william taylor
    the video adapter is a group of electronic components that produce video signals from raw data. sounds like you'll need a new one. what is the manufacturer and model number of your pc? if it's generic youll need to open it up and find the manufacturer and model of your motherboard (the big flat board that everything plugs into)
    any brand will do. you could also try a usb video adapter
  • william taylor
    "manufacturer and model number" i have no idea where to find it as its second hand and i have no manual. its not the adapter as that work in the laptop and with other screens. is the video card the same as the graphics card. Also where can i buy these components
  • Larry Symms Mar 27, 2014
    the adapter is not the cable. it's a group of components that convert data to video
    the manufacturer (e.g. Dell, HP, Compaq, etc) and model number should be on a the outside of the computer. if not you'll need to open it up and look for a model number on the motherboard.
    if you are unable or unwilling to do that than biy a usb video adapterhttps://www.google.com/search?q=usb+vide...
  • william taylor
    william taylor Mar 28, 2014
    i have found this model code on the inside base of desktop, (model oe data serial-pc 30322 021499 0606 c500254-pc 303220112948), iv tryed searching that up but can't find anything.
  • william taylor
    looks like the Evesham Solar Storm model, but runs on windows xp not vista
  • Larry Symms Mar 28, 2014
    this should work:http://www.newegg.com/Product/Product.as...
  • william taylor
    looks like id need to install it and without a screen view i can't. however i have come across this one,http://www.newegg.com/Product/Product.as... let me now that you think.
  • william taylor
    william taylor Mar 29, 2014
    Iv opened up the desk top and where the VGA cable plugs into looks like the port goes straight into the mother board, the part have this code on (EA=0001CFCEA68).where will i find the motherboard number/modle.
  • Larry Symms Mar 30, 2014
    don't bother replacing the motherboard, just get another video adapter. If you're going to replace the motherboard, just replace the whole desktop.
    the link above is NOT a video adapter, it's just a KVM (Keboard, Video, Mouse) switch for using one keboard monitor and mouse with 2 PCs. you want a USB video adapter like this:
  • william taylor
    william taylor Mar 30, 2014
    well the model i have is foxconn-945g7ma-8ekb52,
  • william taylor
    however using there site i couldnt find the model.
  • william taylor
    so i have come to the conclusion that it out-dated so they don't supply a list of compatible components.
  • william taylor
    I've used a number of search engines to find it however none seem to find it.
  • Larry Symms Mar 31, 2014
    found the specs in Newegg. you can use any pci, pci express x16, or pci express x1 video card. http://www.newegg.com/Product/Product.as...
  • william taylor
    william taylor Mar 31, 2014
    thanks i also have a DVI port that has 9 point to it. do you know the DVI type (DVI-I,DVI-A) e.c.t. I and also wanting to get a DVI to VGA converter as well, however i don't have appropriate name.
  • Larry Symms Apr 01, 2014
    there's no dvi port on that motherboard. so you must be speaking of another computer or a PCI adapter. DVI to VGA adapters are pretty standard. http://www.newegg.com/Product/Product.as...
  • william taylor
    william taylor Apr 01, 2014
    thank another problem has occured, i have gone and got a PCI Express x16 video card and fitted it in place. However the power keeps cutting out. I used pc world to get the cards and in the web site i put PCI Express x16 video card and this is the mode it came up with EVGA NVIDIA GeForce 210 PCI-E Graphics Card I have a felling that the card is the wrong one could i be correct and is my desktop in shock.
    your power supply might not be able to put out enough watts to run what you had along with the new card. My recommendation at this point is to return the card and get a new PC.
  • william taylor
    what if i was to replace the power source, would it have to be a particular one. I only ask because i can't afford to buy a new desktop.
  • william taylor
    on the GeForce site it say the PCI-E 2.0 bus support. is the 2.0 the type or somthing else, if so them PC World has put wrong information on there site.
  • william taylor
    newegg says its a PCI Express 2.0 x16.
    you could try a new power supply but if it's something else (like the motherboard) you're not going to fix the problem. This should fit in your case and have the same molex connectors to the motherboard:http://www.pcworld.co.uk/gbuk/components...
    if you get a new PSU and that still has problems you might be able to swap the motherboard. This should work with all of the components:http://www.newegg.com/Product/Product.as...
    all this stuff adds up. You could probably upgrade your motherboard and memory for under $100USD. For example:http://prntscr.com/364q3c but if it were me I'd do at least 4gb of memory.
  • william taylor
    before the power cuts out the screen is still saying no signal. am i right in thinking that its the motherboard all along. and that I didn't need to get a PCI Card.
  • william taylor
    it was a laptop memory in that example. which ones you suggest for the components i already have.
  • william taylor
    also i need the motherboard to run on xp other wise ill have to get a new windows as well
    no video drivers for xp. It'll work but not well. You could switch to ubuntu. Or buy the motherboard I listed first and you should be able reuse all of your existing hardware (hard drives, optical drives, memory, case, power supply, etc)
sainisonu
  • 156 Answers
SOURCE: No Display
Turn off the power and uninstall the RAM and reinstall it.Then boot the computer.
Posted on Oct 25, 2007
buffalonyman
  • 1865 Answers
SOURCE: vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Posted on Apr 15, 2009
  • 3940 Answers
SOURCE: Ethernet port does not work in computer.
Here are some things to check.
  1. In the system setup, ensure that the network adapter is enabled.
  2. Check device manager and see if the driver is properly installed.
  3. If the integrated NIC doesn't work, you can disable it in the BIOS and install a PCI NIC (Less than $20) and the system will work that way.
Posted on Sep 30, 2009
z89s
  • 225 Answers
SOURCE: Gateway DX4720-03 desktop the HDMI stopped working
Make your hdmi port a separate monitor in your display settings. If that didn't help leave a comment and ill try to help you again.
Posted on Jul 02, 2010
SOURCE: I've bought a USB 3RCA
I have the same problem?????
My computer doesnt even see that iv pluged it in !
I am using vista 32 bit service pack 1.
When i bought the cable it didnt come with a Driver (CD/DVD)
Posted on Aug 24, 2010
How do i connect my acer laptop to my evesham TV
Use an HDMI cable, 1,366x768 resolution. You should be able to select mirror (duplicate the laptop screen) or extend (act as a second desktop).
Feb 23, 2015 | Evesham Televison & Video
Need help finding part for Evesham desktop that want connect to my tv. i have found my motherboard model which is foxconn-945g7ma, however when i search for it on the internet i find two types Foxconn
You would only be able to connect that to your TV if your TV has a VGA connector, (also called D-Sub.)
There is NO HDMI or DVI connector on any 'flavor' of that model Motherboard.
Mar 29, 2014 | Evesham Computers & Internet
5 digit evesham tv code
Dear Sir:
go to www.fitness.manualsonline.com or call to your manufacturer TV for get the digits.
God bless you
May 13, 2012 | Evesham Televison & Video
Why doesnt my hdmi cable work from my ps3 to my evesham hd ready tv
Does anything else work on your TV through HDMI?
If not, your TV needs a new main board.
If so, does your PS3 work on any other set that has HDMI?
If not, you PS3 is bad.
If it does work, then it is a hand shaking issue between the two products that unless Sony has a firmware upgrade for, the two will not be compatible.
Apr 10, 2012 | Televison & Video
Horizontal white lines on tv?
i would try it on another television and if that dosnt work then it is probably the module it self, it mght be time to buy a new one
Jun 17, 2010 | Pinnacle Dazzle DVC-100 DVD Recorder
Can't find Evesham LAN driver
Without knowing the model numbers it is hard to know if the driver I found will work. It is worth a try:
http://members.driverguide.com/driver/detail.php?driverid=732417
Jan 15, 2009 | Evesham Axis PC Desktop
Evesham ebox - Sleep function
Hi, Azrul here, from Malaysia. You can disable the sleep function for your HP Media Center m7250n before connecting to tv.
Go to control panel
then go to display
then go to power under the screen saver's tab
then set your power options to never go to sleep at any settings.
Dec 21, 2008 | HP Media Center m7250n (ED842AA) PC...
Monitor issue
there are loads of ways to do it ...call up the 18006249896 and the dell tech support with be able to help out
Oct 28, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
104 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
