TV won't recognize PC through HDMI port anymore
I have had a PC attached to my Mitsubishi WD-73333 through a Sony receiver to the HDMI port 1 and it has been working well for years. Recently, the TV does not recognize the HDMI port when restarted. we have found that shutting the TV off and then switching off the surge protector that all the components (TV included) are attached to then restarting the TV and going through the TV menu to the input setup will make it recognize the HDMI port again. Switching the HDMI cable to the other HDMI ports on the TV does not help - the TV does not recognize the port switched to but recognizes the previous port (the one that the HDMI cable has just been removed from even though it is empty). I have tried attaching the HDMI cord directly from the PC to the TV but the same thing happens. Can you help me?
  • 76 Answers
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Posted on Mar 26, 2014
  • 4 more comments
  • Angelo Chirban
    Angelo Chirban Mar 28, 2014
    The resolution was never changed over the several years that the system worked. I raised it and lowered itper your instructions without success. The problem continues. Thanks anyway.
  • Larry Symms Mar 28, 2014
    what about refresh rate? If that hasn't changed not sure what to tell you. Something's clearly different than it was (hardware or software), I'm guessing you've tried various cords. Have you tried plugging the PC into other HDMI displays?
  • Angelo Chirban
    Thanks for your input. Please remember that the TV HDMI (is recognized) works now. By turning off the TV then turning off the surge protector that has everything attached to it for a minute or so. After turning everything back on and going through the input setup on the TV, it recognizes the HDMI port and all is good. I can't understand why.
    how long is the cable? If it's more than 10 ft it may just be a problem in the cable with signal distortion which the TV has trouble interpreting. Once connected it has enough signal to interpret properly but you may be getting some noise coming through.
    Also, some cables can degrade slightly reducing insulative properties. I would try a short, known working, hdmi cable for a while (although WAF - Wife Appreciation Factor may be an issue). Alway try to eliminate the least expensive component as a culprit.
    might also be able to boost the signal of your PC's hdmi port
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I am trying to set up a yamaha receiver and I can not get it to work. I have a hdmi cable from the receiver to the tv. Is there something special I need to do to get it to come on.
Are you feeding a signal from a blu-ray player, satellite dish or other set top box to the receiver and then HDMI out to the TV? That will work with most TVs. If this isn't working, try new cables. Make sure all of the cables are well seated.
Otherwise, the TV only has HDMI in, no HDMI out. So either you have HDMI out on the receiver to HDMI in on the TV or HDMI in to HDMI in. Neither will send audio to the receiver. Depending on the receiver, you will need to connect one of the TV's audio out ports to an audio in port on the receiver. The WD-60C9 has both a digital audio out and an analog audio out. Both are between the HDMI ports and the composite video in on the back of the tv.
I hope this helps.
Jan 23, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Help!
It is possible that the HDMI ports are blown. The work through their own circuit area in the TV set. This is a particularly complex area.
You will have to send the set to the authorized service rep for an estimate. See if your home insurance plan will cover for this type of thing. Some types of home policies will cover for this type of thing. The cost of servicing your set may be expensive. Damage from a lightning strike will not normaly be covered by warranty.
Jerry G.
Jun 12, 2008 | Mitsubishi WD-Y657 65" HDTV
Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Electro Med Services...
