Question about Dell OptiPlex 780/ 780 Mini-Tower Desktops DVD-RW Burner
Dell OptiPlex 780 with Windows 7 does not play my cd's or dvd's and is missing from device manager
Tower Dell OptiPlex 780 Win 7 pro is not playing my cd's or dvd's and cant find in device manager ?
    Sergeant:
  • 376 Answers
Sounds like a problem of non-detection by the system. If the drive is missing from My Computer then it definitely is a non-detection issue. Try using this file (it's an exe when unzipped) and only required double-clicking.
http://www.geekstogo.com/forum/files/file/8-cdgone/
Posted on Jul 09, 2014
SADHSU
SOURCE: wont burn data dvd
dear
i have this kind of drive ( 7W036-A01) , IT READ AND WRITE CD BUT IT COULDNT WRITE DVD ( EVEN IT READ DVD IN GOOD WAY )
PLEASE CAN ANY ONE HELP ?????
Posted on Sep 07, 2008
PlatoAu
  • 67 Answers
SOURCE: dvd/cd rom drivers
try dell.com for driver downloads for your drive.
or uninstall it from your device manager and reboot and it might fix itself
Posted on Apr 04, 2009
greg_margo
  • 1959 Answers
SOURCE: Dimension E510 dvd burner will not burn
Go to this link and click on the Fixit box. Microsoft has an issue with CD/DVD recognition and created a patch. This happens a lot when Windows Update runs and installs SP3. Hope this solves your problem. If it doesn't, right click on your DVD drive and ensure that recording is enabled. Hope this solves your recording issue.
Greg
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
Posted on May 18, 2009
Musheer
  • 19 Answers
SOURCE: DVD/CD RW does not work
You can try the steps below:
Edit the registry:-
1. Click Start, and click Run.
2. Type regedit in the Open box, and click OK.
3. In Registry Editor, click the plus (+) sign next to each folder name to expand the following registry path:
4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the right pane, right-click Upper Filters, and click Delete.
7. Click yes when prompted to delete the registry value.
8. In the right pane, right-click Lower Filters, and click Delete.
9. Click yes again.
10.Close the window and restart the computer
Please do not forget to rate the solution.
Regards,
Musheer.
Posted on Jun 10, 2009
anandsharad
  • 137 Answers
SOURCE: i have a dell inspiron 1525 laptop and my cd/dvd
The CD, CD-RW, DVD, DVD-RW, Blu-Ray and any other drive that uses a laser to read data from a CD. In general, most optical drive problems can be resolved by:
  • Updating the optical drive firmware
  • Updating the burning software
  • Updating the DVD playback software
  • Updating the computer's video driver in cases of video playback issues
  • Updating the computer's audio driver in cases of audio playback issues
To download the Firmware of your machine click here. i have selected the default 1525 but if you click on enter the service tag, it will give you your computer's firmware. or you can check it in device manager as well.
you can also try deleting the upper and lower filters. in regedit.
in vista. click on start /type regedit in start search.
then continue the action and then click on the +HKEY_LOCAL_MACHINE / + SYSTEM / +CURRENT CONTROLSET / +CONTROL /+ CLASS /+ {4D36E965-E325-11CE-BFC1-08002BE10318} and on the right side look for upper filters or lower filters and delete them. and then restart the computer. it should fix this.
in case the issue is not resolved. you might need to get the optical drive replaced.
if this information was helpful. please rate the solution.
Posted on Sep 25, 2009
My dell optiplex 950 has been reloaded with XP service pack 3. it runs well, has 3 gig ram and ample hd storage.
Why would you want Win XP? It's old, no longer supported and a security liability. Upgrade to Win 7 or 10... the sound drivers will probably load and problem solved.
Dec 26, 2017 | Dell Computers & Internet
Dvd/cd writer will not recognize cd's or blank disk's will recognize dvd but not play.
Did this problem occur after a OS upgrade? Open Device Manager, DVD/CD-ROM drives, open and uninstall the DVD/CD rom. Reboot your machine, Win 7 should apply the correct driver. If you need a driver go to your manufacturer's website. Drivers and support section.
Dec 14, 2012 | Computers & Internet
I HAVE DELL OPTIPLEX 780 DESK TOP WORKSTATION ,THE CD DRIVE IS NOT SHOWN WHEN I OPEN IT
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 14, 2012 | Dell OptiPlex 780 PC Desktop
I have an hp laptop with windows 7 operating system. I am unable to play DVD movies.
HI, Try the following solution
Click Start button, type device manager in the start search box and hit enter key.
device manager window opens
click - sign next to Cd-Dvd Rom devices.
right click on cd-dvd driver and select un-install
it would be missing now
now run the following software
http://support.microsoft.com/kb/929461
hope the problem will get resolved
Apr 18, 2011 | Computers & Internet
Dvd/cd rom drivers
Apr 04, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dell Optiplex GX270 Driver Questions
On the Audio driver question: the answer is yes the Audio driver is what allows you to have sound.
On the DVD software, I did not see any software on Dell link. Download Windows Media, newest version is ver.11
It will allow you to watch DVDs
You can also check this site:
http://www.dvdsoft.net/modules.php?name=Downloads&d_op=viewdownload&cid=1&orderby=titleA
Copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex 780/ 780 Mini-Tower Desktops DVD-RW Burner Logo
170 people viewed this question
Alun Cox
