Question about Mitsubishi Televison & Video
Tv doesn t recognize HDMI cable connection anymore
I have had a PC attached to my Mitsubishi WD-73333 through a Sony receiver to the HDMI port 1 and it has been working well for years. Recently, the TV does not recognize the HDMI port when restarted. we have found that shutting the TV off and then switching off the surge protector that all the components (TV included) are attached to then restarting the TV and going through the TV menu to the input setup will make it recognize the HDMI port again. Switching the HDMI cable to the other HDMI ports on the TV does not help - the TV does not recognize the port switched to but recognizes the previous port (the one that the HDMI cable has just been removed from even though it is empty). I have tried attaching the HDMI cord directly from the PC to the TV but the same thing happens. Can you help me?
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
  • 87 Answers
SOURCE: wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: Samsung HLR6167 keeps flickering on bright scenes
Try turning off your Energy Saving option. (mine is in Menu --> Setup --> Energy Saving).  See if that helps.
Posted on Nov 14, 2009
Where do I plug HDMI cable to a soundbar. I have 3 HDMI inputs but no output
Hello. Your Mitsubishi doesn't support HDMI ARC (Audio Receiver Channel). You will have to use the AVR or the Digital Audio output to connect your sound bar. Sorry.
Aug 13, 2015 | Mitsubishi WD-60737 60 in. HDTV
TV won't recognize PC through HDMI port anymore
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Mar 26, 2014 | Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I am trying to set up a yamaha receiver and I can not get it to work. I have a hdmi cable from the receiver to the tv. Is there something special I need to do to get it to come on.
Are you feeding a signal from a blu-ray player, satellite dish or other set top box to the receiver and then HDMI out to the TV? That will work with most TVs. If this isn't working, try new cables. Make sure all of the cables are well seated.
Otherwise, the TV only has HDMI in, no HDMI out. So either you have HDMI out on the receiver to HDMI in on the TV or HDMI in to HDMI in. Neither will send audio to the receiver. Depending on the receiver, you will need to connect one of the TV's audio out ports to an audio in port on the receiver. The WD-60C9 has both a digital audio out and an analog audio out. Both are between the HDMI ports and the composite video in on the back of the tv.
I hope this helps.
Jan 23, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
