Question about Sony KDL-46W5150 TV
Montor will not turn on
Power indicator light turns on, but no response on the monitor.
    Top Expert:
  • Sony Master
  • 74,251 Answers
Sounds like a main board fault. Contact the authorized service centre for Sony. It will be the best in this case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 26, 2014
The monitor turn on but when I connect with the pc I don't see any immagine
monitor.
1: power light on?
2: OSD work with called up, (menu) hit all montor buttons.?
3: yes, to above.? then, boot windoz in to safe mode? F8 key
still dead and all cables good.?
then RIP , Mr. monitor.
Sep 25, 2013 | Samsung Computers & Internet
After you turn it on it goes to a black screen, then wont turn off.
first check the supply of the LCD monitor check the plug supply usually 110V or 220v use a voltmeter, if the voltage is present look for the indicator lights that is changing when power switch is press,the indicators tells you if the problem is in the power supply area of the LCD monitor or in the screen, usually the problem with the LCD monitors is in the screen check the bulb on top of the monitor check if it is not function well this bulb is responsible for the brightness of the screen if it is defective replace it or maybe the supply of the bulb is defective you can use the power supply of the cathode light as a replacement to its supply that is usually use in motorcycles signal lights.. hope this helps you..
Jul 25, 2011 | Coby 40 TFTV4028 LCD TV
My monitors power light blinks red
I assume you have already try this monitor with other PC, just to be sure before opening up the case.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2010 | X2Gen MG19MY 19" LCD Monitor
Enabling Montors Resulation
you can turn off the resolution but you can either keep it low or high.
you can do this by right clicking on the desktop(without any window opened) and click properties>settings. there you can adjust the resolution. remember the resolution indicates the number of pixels packed in a particular area and you cannot turn it of
Jul 04, 2009 | Gateway HD1900 19" Monitor
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
LCD Monitor power problems
yes the monitor is over heating there should be warranty on the montor
Dec 15, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Sony KDL-46W5150 TV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
