Question about Brother HL-6050DN Laser Printer
BROTHERS HL6050 DN RESET PAPER TRAY
DISPLAY PAPER TRAY RESET
  • Brother Master
  • 783 Answers
Go To Below official Brother Printer Page For Your problem, How do clear the message No Paper from the display Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Posted on Mar 26, 2014
2 Suggested Answers
  • 12 Answers
SOURCE: I am having a problem with the paper tray for
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Posted on Feb 28, 2011
Brothers MFC 8460n no paper when there is paper in tray
Hi, could be the different size of paper. Look, when you send a job to print, if the size of your document is not the same size of the paper (tray 1), the machine will use the MU tray. This tray no have limitation of size paper. Try to put paper on this tray e look what happens. Other way, looks on the Printer, configurations, the size of the paper (tray 1). And compare with the size of your document. Good luck bro
Jul 24, 2014 | Brother MFC Office Equipment & Supplies
I cant get my printer HP2055 dn to print letter paper..it just goes to the legal tray (3). I also can't figure out how to get to the menu on the printer to see if the trays are set correctly.
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
Feb 12, 2013 | HP LaserJet P3005n Printer
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
I have a brothers MFC 5460 CN all in one,with a paper tray jammed so it will not release.how do I get the tray to release
Hi kenttti,
I have provided link here where you can get the instruction on how you can address paper jam with your Brothers printer. It's complete with instruction and illustrations on how to release the tray as well.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother MFC-5460CN All-In-One InkJet...
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
My xerox 8500 will not read that I have paper in the tray and the screen is blank, I can't read anything.
Call Xerox at 1-800-835-6100 report that problem and they will send you a display. It is a known problem and they will correct it .
Nov 04, 2009 | Xerox Phaser 8500/DN Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
Brother HL-6050DN Laser Printer Logo
79 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
