Question about Volant 2005 Dodge Ram - 1500, 4.7L V8 - Ram Air Scoop
How to replace the computer
How do I replace the computer
Power light off
Power surges are damaging spikes of voltage in an electrical systems, caused by lightning strikes, changes or problems with the electrical grid, or large appliances.
Power surges damage or destroy computer hardware by overheating circuit boards and other components.
Surge protectors and other devices are used to protect computers and other electrical devices from power surges.
If damage occurs to a computer from a power surge, a process of trial and error is used to replace the damaged components.
Replace the surge protector or power strip.
If neither was attached to the computer, it is highly recommended that one be used.
Follow the user's manual to open the computer.
The computer manual may have shipped with the computer in book or CD form or may be found online.
Examine the system and make note of any visibly damaged components.
Damaged components may show visible burn damage or no damage at all.
Follow the user manual to remove the power supply.
You will need to unplug the power connections to each device in the computer as well as the system board.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Removal is generally achieved by removing the holding screws and lifting the power supply out of the system.
Follow the user manual to install the new power supply.
Plug the power cables into the computer components and the system board.
Close the case.
Do not re-insert the screws.
Plug the power cable into the computer and attempt to power the computer on.
Replace the power cables to the monitor and computer.
Examine the monitor.
If the monitor does not power on, it will need to be replaced.
Determine if both the monitor and computer power on.
If the monitor powers on but the computer does not replace the system board.
If both power on but there is no video signal, replace the video card.
Boot the system into Windows.
Go to the "Control Panel" and double-click on the "System" icon.
Click on the "Hardware" tab.
Double-click the network card, sound card, and other peripherals that are listed in the hardware tab.
If you replaced the system board, ensure that the device drivers are in place for the peripherals. Replace any peripheral that is still non-functional.
Computer Repair Tutorial Help and Tips
http://www.thepcmanwebsite.com/computer_repair.shtml
Dec 08, 2013 | Dell Vostro 410 Desktop Computer
Computer inside steering collar
more input
if computer bad replace it anything with computer needs maintenance or replacement if failing overall youll have to replace
Nov 09, 2013 | 1993 Toyota Corolla
I can not turn it on. How can I fix a no power problem?
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing and replacing the PC power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNING Before you start troubleshooting remember that you are dealing with electricity that can KILL.
Close the case.
Click on the "Hardware" tab. Double-click the network card, sound card, and other peripherals that are listed in the hardware tab.
Jul 01, 2013 | Lenovo IdeaCentre K320 3019 PC Desktop
94 hyundai scoupe 1.5 non/turbo quit firing after replacing the computer what could be the problem
WHAT COMPUTER DID U REPLACE? WHY DID THE OTHER COMPUTER BURN OUT. THERE MUST BE A PROBLEM IN THE HARNESS CAUSING THE COMPUTER TO BURN UP. COMPUTER DO NOT JUST BURN OUT FOR NO REASON. I SUGGEST TRACKING DOWN THE ISSUE FIRST. GIVE ME MORE DETAILS AND i WILL BE ABLE TO TELL YOU WHAT NEEDS TO BE CHECKED .
Mar 15, 2013 | Hyundai Motor 1994 Scoupe
Computer won't turn on completely. I can hear it but the screen is black
Try connecting a different monitor to your computer.
If it works, then your monitor needs to be replaced.
If not, then the video-card in your computer needs to be replaced.
Try connecting your monitor to a different computer.
If it still is "black", then your monitor needs to be replaced.
If your monitor works, then the video-card in your computer needs to be replaced.
Sep 28, 2010 | Computers & Internet
How to replace cpu on a micron v1000 laptop
As a rule, laptop CPUs are not replaceable. They are flow solder which makes it very difficult to remove and replace parts without damaging the adjacent circuit.
This is a very old obsolete computer. I would replace the entire computer.
Sep 13, 2010 | MPC Computers Transport T1000 PC Notebook
2003 Boxster. PSM and ABS dash light stay ON
computer is expensive before i invested in one id try to replace the sensors that control those circuits if that dosent solve the problem then id try changing the proms in the computer then lastly the computer.
Apr 04, 2010 | 2003 Porsche Boxster
Compac SR2011WM motherboard
replacing the mobo is much cheaper that to purchase a new computer but purchasing a new computer is much better than replacing your mobo. because in the near future, you need to upgrade your system for better use.
Mar 29, 2010 | Computers & Internet
Hanging computer
check the cpu fan when you start the computer... does it turn. if not replace it.
Robert
Sep 03, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Volant 2005 Dodge Ram - 1500, 4.7L V8 - Ram Air Scoop Logo
80 people viewed this question
Top Volant Wine & Spirits Experts
deton8 von Splosion
Bill Boyd
Dave braun
Dave braun
Are you a Volant Wine and Spirit Expert? Answer questions, earn points and help others
