I am getting the problem fatal:no bootable medium found!system halted while installing xp in oracle vm virtual box.please provide the solution
  • 177 Answers
SOURCE: Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Posted on Nov 26, 2008
  • 31 Answers
SOURCE: Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
Posted on Mar 20, 2009
  • 149 Answers
SOURCE: Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
hari007_in
  • 138 Answers
SOURCE: chassis intruded ? fatal error... system halted
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Posted on Sep 29, 2009
  • 6 Answers
SOURCE: Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Posted on Feb 16, 2010
Oracle virtual machine
Configure the VM to allow it to access/boot from the "virtual" disk-drive.
Mar 26, 2014 | Office Equipment & Supplies
Want to install Topo for XP service pack 2 onto Windows 7
install virtual box, a free virtual computer from oracle. It reserves disk space and runs a separate operating system, in a window on your desktop. Install virtual box, install windowsXP, install your software.
Hope that helps.
Apr 07, 2013 | GPS
Sony Vaio laptop with Windows 7 and xp install?
You can download the Microsoft virtual machine or another VM system.
Like this:
http://www.oracle.com/us/technologies/virtualization/oraclevm/index.html?sckw=srch:virtual-machine&SC=srch:virtual-machine
After install make a virtual hard drive on your VM machine of at least10 gig. Then add your DVD/CD rom drive to the VM and put yourinstall CD/DVD in the drive. Set VM machine to boot from CD.Install on VM hard drive from within the VM machine, Type in KEY code,Bam! you now have a win xp VM!(Note: Games and stuff may not work in the VM as they do not use your video card but a virtual video card that is pretty limited!)
Aug 06, 2012 | Sony Computers & Internet
Fatal Error, Chasis Entruded, System halted appear at first time boot up. and if I again restart, sometime it works continuously till I shut down the PC and if I boot up again some times it works or some...
Good day try to remove the memory card, sound card and video card, clean the copper leads using an eraser and try to check all the connectors specially the hard disc, do this and it will resolve the problem, best regards.
Aug 19, 2011 | ASUS P5PE-VM Motherboard
I want install oracle 8i in windows 7
You can't install that Oracle version directly on a Windows 7 machine, but you should be able to install it on XP Mode.
Oracle 8.1 is not supported on Windows 7. It is never intended to be used on Windows 7. You have to look at virtualisation (Virtual Box, Virtual Pc, WMware), to get Oracle 8i installed on Win XP, 2000, 98.
Mar 31, 2011 | Computers & Internet
Asus P5RD-2-UM acpi bios revision 0811. Press del to run setup Press F8 for BBS popup initializing usb controllers..done. 992mb =32 mb shared memory avto detecting pri master ide hard disk pri master...
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Dec 20, 2010 | ASUS P5RD2-VM Motherboard
Sir, please provide me with the soloution and my problem is that my client have a system which have window 7 and the client is using mstar which runs on oracle 8i and when i install the oracle 8i it is...
I am sorry to say but oracle 8i is not compatible with windows 7. If you would like this to run you would be needing a downgrade to xp. But if you insist on using windows 7 what you could do is install a virtualization software like virtualbox and install windows xp on it and the software you need. So, it would be like running windows xp in windows 7.
Apr 29, 2010 | HP Pavilion a1610n PC Desktop
How to install oracle 8i in windows 7
Oracle 8i is never intented to be used on Windows 7. Oracle will not support it. I think you have to look at virtualisation (Virtual Box, Virtual Pc, WMware), to get Oracle 8i installed on Win XP (or Win 2000/98).
Mar 11, 2010 | Computers & Internet
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
23 people viewed this question
k24674
jasbo
jasbo
