Question about Acer AL1716 17" LCD Monitor
Slow monitor monitor is slow coming on then when on website clicking out of second tab flashes black
  • Teresia Ware
    Teresia Ware Mar 26, 2014
    It is an acer AL1716
  • Acer Master
  • 3,320 Answers
Check the video/display settings in your OS.
System Preferences in mac os
Screen resolution in windows.
Use recommended settings.
Posted on Mar 27, 2014
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
Tip
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
Monitor flashes on websites
if problem persist when opening multiple tabs, your RAM (random access memory) might be failing or is cluttered by a virus or program. If there is not enough memory available, the screen will go crazy or have a hard time coming on. Next you can check your video card if its not an integrated one. You may need to use a cheap used card to make sure that it is not a video card problem.
Pen drive is slow
Slow Transfer on a USB Flash Drive b> Using a USB flash drive is a convenient way of transferring data and files from one device to another. However, sometimes you may find that your USB drive is slow to transfer files onto your laptop or PC. This lag may also cause your desktop or laptop to slow down while you use other programs. You do not need to replace your flash drive and buy a new one. You can fix a slow file transfer problem in just a few steps.
b>Plug your USB flash drive into your computer. Click the "Start" button and select "My Computer." Right-click the USB icon from the My Computer window and click "Properties" from the menu that comes up. Go to the "Hardware" tab and select your flash drive once you find it in the list of items. Then click the "Properties" option in this menu. Choose "Policies" tab within the Properties menu. Turn on the performance optimization option and click "OK." Click "OK" again to exit out of the Properties dialog box. Go back to the My Computer window and right-click on the USB icon. Select the "Format" option from the list of choices. Select the "NTFS" file system and choose "Quick Format." Press "OK" to confirm the choices and to initiate the formatting. Wait for the drive to finish formatting before ejecting it and removing it from the computer.
USB Flash That Is Slow and Damaged
b> USB flash drives are used to transport data between computer systems. Because it is essentially just a small hard drive, the USB device can become damaged and slow down in performance due to viruses or damaged files. To correct these problems and fix the USB flash drive, you must reformat the drive. This removes all data from the drive, returning it to its factory settings.
Plug the USB flash drive into a USB port on the computer system. Close any AutoPlay window that may load onto the screen. Click "Start" then "(My) Computer." Right-click the removable device icon that appears on the screen. Select "Format" from the pull-down menu. This loads a format options screen. Click "Yes" and the computer formats the USB flash drive, removing the damaged content and returning it to the factory settings.
ReadyBoost With a Slow Flash Drive
b>The ReadyBoost feature in Windows has the ability to increase the speed of low-RAM computers by caching program data on a flash memory device. However, the device must meet minimum performance characteristics in order for Windows to enable ReadyBoost, because ReadyBoost may not meet expectations when used on a slower device. If you still want to use ReadyBoost with your flash drive or memory card, you can make a change in the system registry to force Windows to use the device.
Insert the flash device that you would like to use for ReadyBoost. Open the Start menu, and click "Computer" to see the icon for the device. Right-click the icon for the flash device, and then click "Properties." Click the "ReadyBoost" tab at the top of the window. Clear the check from the "Stop retesting this device when I plug it in" box, and then click "OK." Remove the flash device. Open the Start menu again. Type "regedit" in the "Search programs and files" box at the bottom, and then press "Enter" to run the Registry Editor. Double-click the folders "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT," "CurrentVersion." and "EMDMgmt." Locate and click the folder for your flash memory device under "EMDMgmt." In most cases, you can determine the correct folder because it contains the name of the device's manufacturer. Double-click the registry entry "DeviceStatus" on the right side of the window. Change the number under "Value Data" to "2" and click "OK." Double-click "ReadSpeedKBs" on the right side of the window. Change the value to "10000000" and click "OK." Repeat this process with the "WriteSpeedKBs" registry entry and close the Registry Editor. Reinsert the flash memory device, and return to the "Computer" window. Right-click the icon for the flash memory device, and then click "Properties." Click the "ReadyBoost" tab. Windows now displays an option to enable ReadyBoost on the device. You might install a usb 3 card the speeds are much faster cheap and easy to install. Hope this helps.
Jan 08, 2013 | Electronics - Others
Driver for Synaps mw9bbk
The flashing power light and very slow display is an indication that the internal power supply board is failing. This is usually caused by bad filter capacitors on the board. You should be able to repair the unit by replacing the bad capacitors.
Sep 25, 2012 | Computers & Internet
My monitor slows down
Sounds like an issue with you PC not the monitor.
Try updating your display/graphics card drivers.
Welly250
Jul 02, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Thinkpad R40 slow to boot, very slow in all other aspects. It can take close to a minute to just open Windows Explorer.
Hello bd35,
Welcome to Fixya!
When you say "slow to boot, very slow in all other aspects." There is a change that your computer might have been infected with a virus. But let's not jump into conclusions, I'm just setting proper expectation here that that can be a cause.
You might want to consider: - Disconnecting extra peripheral devices i.e. printers, scanners, USB flash drives or ext. HDDs - Disabling all the start-up items and services, here's how: 1. Click "Start" 2. Click "Run" 3. Type "msconfig" 4. Go to the "Startup" tab and click the "Disable All" button 5. Go to the "Services" tab, check the "Hide all Microsoft services" check box, and click on the "Disable All" button 6. Click the "Apply" button, and the click "Ok" button. 7. Then "restart the computer.
Aug 12, 2011 | IBM ThinkPad R40 2723 Notebook
Slow pc start up
If the computer comes up slow. Try the steps below.
Click start then run then type in msconfig
Click on the startup tab
Click on Disable all then click apply
Click on ok then restart.
Mar 07, 2009 | Microsoft Computers & Internet
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
Acer AL1716 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
