Question about Acer AL1716 17" LCD Monitor
Monitor flashes on websites
Monitor is slow coming on then when on website clicking out of second tab flashes black
    Problem Solver:
  • 12 Answers
If problem persist when opening multiple tabs, your RAM (random access memory) might be failing or is cluttered by a virus or program. If there is not enough memory available, the screen will go crazy or have a hard time coming on. Next you can check your video card if its not an integrated one. You may need to use a cheap used card to make sure that it is not a video card problem.
Posted on Apr 03, 2014
When I go to a website that has a dark or black background, the monitor goes black completely. When I change to a website that has a lighter colored background, all is well.
The driver may need to be updated. You can update the driver by doing one of the following:
Method 1:
Navigate to the manufacturers website
Locate the support section
Search for updated driver using product model or serial number
Method 2:
(using windows)
Open control panel
Click on Hardware and Sound
Under Devices and Printers click on Device Manager
Enter Admin credentials if prompted
Click the drop down tab for monitors Under monitors right click each device under The monitor section and select Update Driver Software...
Also, ensure (if using Windows) that Windows Update is set to automatically install updates and drivers as they become available
If using windows use this link for additional help: https://support.microsoft.com/en-us/help/15048/windows-7-update-driver-hardware-not-working-properly.
Jul 05, 2016 | Computers & Internet
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
Slow monitor
Check the video/display settings in your OS.
System Preferences in mac os
Screen resolution in windows.
Use recommended settings.
My monitor slows down
Sounds like an issue with you PC not the monitor.
Try updating your display/graphics card drivers.
Welly250
Jul 02, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Samsung syncmaster 23'' wide led SA550
Update the firmware for the monitor from the Samsung website.
Jan 20, 2012 | Samsung Computers & Internet
Cant find download for drivers xp think vision L150 moniter
you dont really need a driver for this monitor but here is a link to where you can get the color setting and so on for it. click here
Nov 30, 2009 | IBM ThinkVision L150 (Black) 15" LCD...
Mp3 Files Slowed down and Garbled
I would go ahead and upgrade the firmware. I might suspect that the sampling rate was too high, but it is playing fine on other mp3 players.
Here are other helpfu lhints:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 04, 2009 | SanDisk Sansa Clip MP3 Player
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Black Screen
Edwards,
What you mean by replaced the fuse? Are you replaced the capacitors on the AC Adapter. If so, Then it's not the only problems. The main problems is the backlight inverter needed to be replaced. Go check out my website @ www.3rd-rocks.com
and click on LCD Parts. If you have any questions just email to to me @ cjt@3rd-rocks.com Have a nice...Happy July 4th!
CJ
Jul 04, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Aug 27, 2007 | Hyundai L91A 19" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
