Question about Suspension & Steering for Cadillac Allante
Sterring/magnasteer 1998 cadilac devile 4.6
On dash panel i have amessage service steering sys.ihave replace a sterring boot that had slip of
  • 46 Answers
Have got the air out of the system,as the boot came off there could be grit on the boot face
Posted on Jun 04, 2014
94 cadilac devile
Assuming battery Ok, check main fuse box (usually under bonnet) and if fuses ok it could be a stuck relay. If there are identical relays in that box you could try swapping them with battery first disconnected.
Jan 13, 2016 | Cars & Trucks
Where can i find the diagram for the fuse box of a 1994 cadilac devile
general motor 1990/1998 chilton manual contents 6-43 chassis electrical you will find what you are looking for.
Feb 21, 2011 | 1994 Cadillac DeVille
Dash lights out in 1998 saturn sl and cant find fuse for it
Lower left dash panel cover has pop out panel on back is a diagram with specific fuse size and purpose Near your left knee left of sterring wheel on dash panel rectangle pop off panel
turn it over voila' directions to the fuses..
Jun 16, 2010 | 1998 Saturn SL
Cadillac deville 1998 power steering /magnasteer makes noise turning
  • Check the steering fluid maybe you need to add some and also check the hose make sure there are no leaks and if the noise still there after you add a steering fluid visit a mechanic and check the hydraulic of the steering wheel.
Feb 12, 2010 | 1998 Cadillac DeVille
Power steering makes noise and vibrates when turning . Is this a pump problem or something to do with magnasteer ?
  • Check the Steering fluid first. and check the hose of the steering fluid make sure there is no leak. And after you add a steering fluid and still there is a noise visit a good mechanic and advise the mechanic to check the pump.
Need a wiring electrical diagram for 98 cadilac
The Auto Parts stores here carry Chilton's or Haynes repair manuals that usually have wiring diagrams in the back.
Jan 28, 2010 | 1998 Cadillac DeVille
Diagram of cadilac northstar engine exploded view of a cadilac northstar engine
need 1998 northstar engine diagram to change the head gasket thanks
Sep 30, 2009 | 2001 Cadillac DeVille
At start up I get this reading on the info Panel Service steering
Hello, The (service ps mesage) usually accurs w/ the power steering presure switch failes or wire chaffs against the rear manafold heat shield. the ps presure switch is located in the high side line and reacts w/ the ac system.(cuts compressor operation durring hard turns) its usuall in the rear twards the fire wall down by the rack and pinnion.the wires usually rub through on the rack heat shield and set the illuminated mesage.hope this helps. thanks
Jun 05, 2009 | 1997 Cadillac Eldorado
Shift lever on column came loose inside column.
no, u shouldn't have to pull the steering wheel. pull the cover off the column, there are 2 or 4 nuts that hold the column up to the dash, remove them and let the column lay on the seat- u should disconnect your battery before doing so. you can get to the shift tube from there- most likely u'll find that the bushings have gone bad and need replacement.
May 27, 2009 | 1995 Ford Aerostar
Power steering failure
Problems with electronic variable-assist systems include all of the same things that can go wrong with a conventional power steering system (leaks, center wear in the steering gears, pump & hose failures, etc.), plus problems with the control electronics including the vehicle speed sensor circuit, the solenoid valve and control module. Accurate diagnosis, therefore, is essential to minimize warranty returns. Most of these systems provide diagnostic fault codes that can be accessed with a voltmeter, test light or scan tool to pinpoint the nature of the fault (if the fault is electronic rather than mechanical or hydraulic).
If power to the solenoid or control valve actuator is lost, the valve keeps the bypass circuit closed so full power assist is provided under all driving conditions. The only indication of trouble, therefore, might be a loss of road feel and/or increased steering sensitivity at highway speeds.
It’s important to remember that variable-rate power steering only reduces the amount of pressure that reaches the steering gear at higher road speeds. The only way it could reduce power assist at low speed would be in the unlikely event the actuator or solenoid valve failed in the open position. This could cause a noticeable reduction or loss of power assist.
On GM’s Magnasteer racks, loss of current to the magnetic coils would cause a loss of power assist at low speed. Coil resistance can be checked with an ohmmeter, and should read about two ohms. An infinite (open) reading indicates a bad coil (requires replacing the rack since the coils are not serviceable). Checking for shorts between both sides of the coil assembly and rack housing is also recommended.
The system does have self-diagnostic capability, but there is only one fault code: C1241 (Magnasteer circuit malfunction). The code is set if the module detects an open or a short in the coil circuit. If this code is present, the Magnasteer system is disabled and will not vary the steering effort as vehicle speed changes. The C1241 body code can be read with a Tech 2 or equivalent scan tool. The Tech 2 tool can also be used to perform a Magnasteer function test. The test varies the current to the coil so you can check for a change in steering effort when turning the steering wheel.
Replacement racks for variable-assist power steering applications are available with or without an EVO control solenoid. As long as the original EVO control solenoid is working OK, it can be removed and installed on the replacement rack to save your customer a few bucks. There’s no need to replace the whole rack if only the EVO solenoid valve is defective.
On GM Magnasteer applications, the whole rack must be replaced if the rack or control unit is defective because the Magnasteer unit is part of the rack. Handle with care because the permanent magnets inside the Magnasteer valve assembly and connector are fragile and can be easily damaged.
Good luck and hope this helps you understand the Steering system on your STS to save you some money on what to look for and what to look out for if your going to have a auto shop repair it. Such as the Valve is replaceable and it may just be a bad wire connection.
May 22, 2009 | 2002 Cadillac Sts
Suspension & Steering for Cadillac Allante Logo
73 people viewed this question
Top Cadillac Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
John Totten
John Totten
Are you a Cadillac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
