Question about Whirlpool Washing Machines
Whirlpool awm 5105 electricity trip
Each time I start my washer it runs for a minute or two and then causes the power to trip or cut out in the whole house, what part could be causing the problem?
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
BIKER T
  • 909 Answers
SOURCE: AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Posted on Oct 24, 2007
jason0110
  • 66 Answers
SOURCE: My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Posted on Jun 14, 2008
  • 135 Answers
SOURCE: Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Posted on Dec 31, 2008
Whirlpool AWM 312 front loading washing machine motor does not spin.
Hi Sachinl, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Whirlpool Washing Machines
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Whirlpool awm 5105
check brushes on motor...............
cheers
Mar 03, 2015 | Whirlpool Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Code reading f 21, whirlpool, front loader, washer, duet sport
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Mar 03, 2010 | Whirlpool Washing Machines
I have a PW1686 power washer but it runs for a few minutes then cuts off. After a few minutes it starts again then goes through the cycle of on and off. Kindly tell me what are the possible causes.
The problem sounds internal (perhaps the temperature cut-off switch or the auto-start-stop switch). For safety and possibly warranty reasons, you should not open the case to investigate or repair; take the unit to your local service center.
Oct 08, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
