Question about Panasonic Viera TX-32LX70 32 in. LCD TV
Red LED blinks four times
Push power button get the usual double relay clicks. Green Power On LED flashes as usual for a few seconds, screen flashes quickly then TV powers down. LED then gives red four blinks error. Service manual suggests this could be A board, P board or XY board. I have replaced P and A boards completely but still get four blinks error. I am loathe to spend more on other boards as I've heard of people replacing all boards and it still shows a problem. Is it maybe a problem with the screen or LED strips?
    Top Expert:
  • Panasonic Master
  • 75,404 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 26, 2014
  • D Evns
    D Evns Mar 26, 2014
    Yes, as mentioned, I worked out from the Service Manual that four blinks on this model is a problem with A board, P board or XW board. Having replaced those, I still get the four blink error
2 Suggested Answers
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
Canon PIXMA MP145 blinking power LED and alarm LED.Displays E...2....7.please assist me
E27 means waste ink absorbed is full need to clear out but you still can't print because only 80% or 70% are full.try this method to solve you problem.
Resetting Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970 procedure:
•Turn off the canon printer
•Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
•Hold the Power Button, release the Resume Button.•Not releasing the Power Button, double click “Resume” and release Both Buttons.after that wait the green flash will become light on then.
•Click “Resume” for Four times
•Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
if this ok so u can print or can't. i still suggestion you bring you printer to computer shop for clear out inside spam printer.
Aug 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
154 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
