Question about Kitchen Ranges
OVEN light shot in the Kitchenaid Superba
Do I have to replace the circuit board?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Apr 05, 2014
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
I have a KitchenAid Double Built In Oven Superba KEBS277DWH1. The digitial screen keeps lighting up saying to SET PROB TEMP. Any insight on how to set the prob temp? Thanks!!
Your oven is asking for you to insert and set your prob, Have you used this feature before? If not your circuit to the prob has failed and will need to be either replace or removed to use your oven again. The control is looking for the prob and for some reason does not see it or wants you to give your control the proper command to continue. If you are using your prob, enter the correct temperature for the product your cooking and then continue with the control boards request for information. I you have never selected this feature, the circuit has failed and thinks you have. At this point you can order a new prob harness, or remove the circuit to cook.
Good Luck
Sep 09, 2011 | Ovens
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Can we light a gas oven manually, it is a kitchenaid superba
No, You have to replace it. When the ignitor grows weak, it does not allow enough voltage through it to open the gas valve. Very common problem. Good Luck, Appliance Specialists
Jan 31, 2010 | Ovens
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven lights not working. replaced both bulbs. both lights still not working. Is this circuit fused, if so, where is fuse located?. First problem on this Kitchen aid Superba in 12 years. John.
The oven lights get power from the main circuit board.
Access the circuit board and check output voltage on board terminals P4-4 to P4-1.
No voltage would be a bad board.
If you get voltage at these terminals the wires or sockets are bad.
The board is not repairable. Only replaceable.
Mar 15, 2009 | KitchenAid Kitchen Ranges
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
