Image chinois rdfedfedsffffffffffffffffffffffff
    Master:
  • 397 Answers
Please clarify.
Posted on Mar 26, 2014
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Tip
T?l?charger les vid?os de YouTube, Metacafe gratuitement?
Comment télécharger les vidéos de YouTube, Metacafe Gratuitement?
Video Sharer est un outil facile à utiliser et puissant logiciel multimédia. On peut télécharger gratuitement les vidéos audio de YouTube, Metacafe, DailyMotion, Yahoo, Google, RedTube, Tube8, YouPorn, XNXX, Break, PornoTube etc. D’éditer et de convertir la vidéo audio en différents formats.
Il supporte le multi-langue: L’anglais, Japonais, Français, Allemand, Espagnol, Italien, Chinois. Propre et sûr: aucun virus, aucun spyware, aucun adware. Comment télécharger les vidéos de YouTube, Metacafe? Pas à pas:
utube.png You-Tube video "OX7a7uBoCeU" placeholder (do not delete) utube.png
Etape 1 Téléchargez et installez Video Sharer, Puis exécutez-le.
Etape 2 Vous pouvez copier et coller URL de la vidéo pour télécharger la vidéo de différents sites web. Copier l’URL de la YouTube, Metacafe vidéo, cliquez sur “Ajouter URL”, cliquez sur OK. (Vous pouvez également: cocher la “capture Automatique“, il peut automatiquement télécharger des vidéos en ligne.)
Etape 3 Clic Droit ou Double-clic Gauche sur la vidéo téléchargée, vous pouvez regarder la vidéo directement. Cliquez “Ouvrir le dossier des vidéos” pour obtenir les audio vidéos téléchargées.
En outre, terminé le téléchargement, puis vient la conversion.(Avant la conversion, vous pouvez éditer la vidéo: Faire des sonneries, Powerpoint video etc.) Sélectionnez l’une des vidéos, et cliquez sur “Profil”, choisir la vidéo audio formats et convertir. Puis mettre la vidéo audio pour iPod, iPhone, PSP, Sansa Fuze, PS3, Zune, Nokia etc. En plus de, Video Sharer soutiendra également le téléchargement par lots et la conversion en lots. Commodité, très facile à utiliser.
Download edit convert video tutorial
on May 24, 2010 | Computers & Internet
Hi, i'am aladdin from DRCongo, i want use my nokia chinois N97 us modem to my pc (toshiba tecra M) so that i ask you, how can i have a free pc driver
Dear Aladin,
N97 is a very advanced phone,all you need to do it install PC suite on pc and click on internet tab on when it loads >> hit connect >> it should connect instantly provided your SIM card has GPRS activated. please select required medium of connection in PC suite ( Bluetooth or USB cable)
besides this i dont think you need anything else to have the net running :)
May 04, 2011 | Nokia N97 Cell Phone
I have many problem with my nokia e71 chinois 1/invalid sim 2/imei introuvable 3/i can't find his atf box 4/can't connect to internet
it may be due to network lock, contact service provider if it locked , you can get unlock codes here http://www.wickedunlock.com/nokia-e71/rs11wp9/
you need to specify the country and network provider,type *#06# to get imei ,check settings,try gprs function to connect internet
Dec 22, 2010 | Cell Phones
How do i change my picture size
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. 1
jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.1-800X800.jpg'); }); Open Microsoft Paint. Paint is usually found under "Start," "Programs" and "Accessories."
  1. 2
jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.2-800X800.jpg'); }); Click on the "Image" menu, and choose "Attributes." This will open the "Attributes" box.
  1. 3
jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.3-800X800.jpg'); }); Choose which "Units" you would like to resize your image in. The options are "Inches, "Centimeters" and "Pixels."
  1. 4
jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.4-800X800.jpg'); }); Enter the "Width" you would like the image to be.
  1. 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.5-800X800.jpg'); }); Enter the "Height" you would like the image to be.
  1. 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.6-800X800.jpg'); }); Click "OK." Your image should now be the appropriate size.
Aug 14, 2010 | Lexmark X2500 All-In-One Printer
How do you install quicktime from a cd-rom
Installation
If you already have QuickTime installed, then we recommend to uninstall it first. After the uninstallation you should reboot your computer.
Now run the installer (QuickTimeInstaller.exe)
Click on the next button on the first page on the installation wizard.
Accept the license agreement.
Now you will be on the Destination Folder page. Uncheck the box for Automatic check for updates. You don't need that.
Click on the Install button. The installation will now begin.
Click on the Configure File & MIME Types button that is shown on the last page of the installation wizard. If you don't see the button, then don't worry, the file and MIME types can also be configured in the QuickTime control panel (see step 3).
File types:
At the bottom, uncheck the box in front of Notify me if other applications modify these associations.
Uncheck everything except these:
* Video - QuickTime Movie
* Miscellaneous - QuickTime HTML
Optionally you can also safely enable these:
* Audio - Sound Designer II
* Audio - GSM audio
* Audio - AMR audio
* Audio - CAF audio
* MPEG - 3GPP media
* MPEG - 3GPP2 media
* MPEG - AMC media
* MPEG - AAC audio
* MPEG - AAC audio (protected)
* MPEG - AAC audio book
* MPEG - Video (protected)
* images - MacPaint image
* images - PICT image
* images - QuickTime image
* images - SGI image
* images - TGA image
* images - JPEG2000 image
MIME Types:
* Streaming - SDP stream descriptor
* Streaming - RTSP stream descriptor
* Audio - WAVE audio
* Audio - MIDI
* Audio - AMR audio
* Video - AutoDesk Animator
* Audio - AIFF audio
* Audio - uLaw/AU audio
* Audio - QualCOMM PureVoice audio
* Audio - GSM audio
* Audio - CAF audio
* MPEG - 3GPP media
* MPEG - SD video
* MPEG - AMC media
Click on the Finish button.
Mar 12, 2010 | Apple QuickTime
How do I create a form field in adobe acrobat pro cs4 that will accept a photo?
Form fields will not accept images. The only way you can add an image is in a pdf that is already created. You have to use the "Paste Clipboard Image as a Stamp".
This is from the Acrobat Help file.
Here are the steps:
You can use the Paste Clipboard Image As Stamp tool to add images to a PDF. You can copy most image formats from drawing and image-editing applications, such as Adobe Photoshop and Adobe Illustrator. If you want to add the image to PDFs repeatedly, create a custom stamp of the image.
Note: The Paste Clipboard Image As Stamp tool isn’t available until you copy an image.
  1. Copy an image by doing one of the following:
    • In Acrobat, choose Tools > Select & Zoom > Snapshot Tool a_snapshot_sm_n.png, and select an image from a PDF.
    • In another application, select an image and choose Edit > Copy.
  2. Open a PDF.
  3. Choose Tools > Comment & Markup > Stamps > Paste Clipboard Image As Stamp Tool.
  4. Click in the PDF where you want the image to appear.
  5. Do any of the following:
    • To move the image, drag it.
    • To resize the image, select it and then drag one of its handles. Press the Shift key when resizing the image to maintain the original proportions.
    • To change the image properties, right-click it and choose Properties.
    • To delete the image, right-click it and choose Delete.
Nov 18, 2009 | Adobe Acrobat 7.0 Professional
Record images
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card SHQ 2592 x 1944 3 images 69 images 139 images HQ 2592 x 1944 11 images 204 images 409 images SQ1 1600 x 1200 27 images 515 images 1030 images SQ2 640 x 480 144 images 2663 images 5324 images
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Computers & Internet Logo
David Payne
David Payne
