Question about Olympus X940 Digital Camera
Camera Not Working
Hi when I switch On Camera The Zoom Up & Stop but The viewer Display is Black
How do I zoom in and out on a photo?
This camera has a 9mm lens, and while shooting, you can't zoom. For that you need a zoom lens. You can buy one from Samsung.
I checked the manual, and it also does not show how to zoom in on a picture when it is on the display. So I guess, you should view it on a computer, or tablet ant use the picture viewer on that device to zoom in.
Be aware you have a great camera and the result with a prime (one focal length) is superior to the results make with a zoom lens.
But if you don't like to move around, to farm the picture, a zoom lens can be convenient.
Oct 07, 2014 | Samsung Nx Mini Smart Camera With 9mm Lens...
Hi, I have a Sony Cybershot camera, and the zoom doesn't work. It did use to work, so i'm not sure if i've pressed something to stop it working. Please advise.
To determine if it is a faulty zoom, switch off and remove battery then reinsert battery try again then go into the camera menu and look for the item which says reset camera settings to default or similar. (sorry I don't have the menu to hand but if you can't find the option I will check for you) Do this and try again. If the zoom does not work then you have a faulty zoom and the camera will need to be dismantled to repair.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 21, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Sanyo vpc e890 when I go to take a photo the viewer is all black and when I take the photo it's also coming up black.. I can still view my GOOD photo's that actually took the picure but recently every new...
I have a simular problem with my Sanyo. I know this sounds weird, but I have noticed if you shake the camera a little, the photo viewer comes back and pics can be taken. Also.. there is a spot that says 3x Digital zoom on the top of the camera, I also noticed if I put a little prssure on that spot with my fingers, the viewer comes back. I don't know if something might be loose, but thought maybe this information would help you.
Jun 06, 2010 | Sanyo Xacti VPC-T700 Digital Camera
D80-viewer and display stay black, the flash
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
Dec 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Viewer turns off (black) when folded back against the camera.
When the big LCD is black the view finder will turn on, right?
You need to replace a new hinge unit. Here is similar solution
How to fix an intermittent display LCD on Canon PowerShot S5IS
Jun 26, 2009 | Canon PowerShot S2 IS Digital Camera
Minolta dynax 5 camera, diplay has disappeared
does this model have the eye viewer also? if so check and make sure the switch is toggled to displayed and not for the eye viewer. look into the eye viewer and you should see your display. it is simple switch to toggle it to the display mode.
Apr 10, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Re- fuji finepix s5000 digital camera
when the camera is turned on the screen says zoom error and whem pressing the zoom button the camera makes a noise and the lens does not move
Oct 12, 2008 | Fuji FinePix S5000 Digital Camera
No display object on LCD viewer screen
press the disp/guide and see if the display changes..if not then repair
Jan 19, 2008 | Olympus SP-350 Digital Camera
Black viewer and black photos
THE MOST LIKELY REASON FOR THIS COULD BE EITHER THE SHUTTER IS NOT OPENING(IN THIS CASE WHEN YOU HALF PRESS THE CLICK BUTTON YOU SEE SOME SORT OF SNOWY PICTURE )IF NOT THEN THE CCD HAS GONE FAULTY AND IN BOTH THE CASES THE HARDWARE NEEDS TO BE CHECKED THERE IS NOTHING YOU CAN DO ABOUT IT YOURSELF
Nov 17, 2007 | Fuji FinePix F20 Digital Camera
Olympus X940 Digital Camera Logo
26 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
