Question about Canon MF8050Cn AllInOne Laser Printer
How do I override the tone count?
Flashing I'm out Cyan toner, in the past I've been able to override, I just can't remember how!?!
HOW DO I ESCAPE ERROR C-2A01 FROM MY KONICA MINOLTA C650
C-2A01 is for the cyan toner not the imaging unit. The unit is having trouble reading the counts. Try replacing the Cyan toner and let me know how it responds after.
Feb 16, 2015 | Konica Minolta Office Equipment & Supplies
Please on my Sharp copier Mx 4501n display error code F2-65 what is the cause
Your machine is starved for cyan toner. Either the toner supply pipe is blocked or the CRUM counting chip on the back of the cyan toner cartridge has burnt out or wound down to zero. Try replacing your toner cartridge. If still no go you'll have to take out the drums, developer tanks and transfer belt, hold a piece of paper under the cyan supply pipe spout and tap the pipe to break up the toner.
Jun 08, 2013 | Office Equipment & Supplies
F2-65 shows on my sharp mx4501n copier what will i do
Your machine is starved for cyan toner. Either the toner supply pipe is blocked or the CRUM counting chip on the back of the cyan toner cartridge has zapped out or wound down to zero. Try replacing your toner cartridge. If still no go you'll have to take out the drums, developer tanks and transfer belt, hold a piece of paper under the cyan supply pipe spout and tap the pipe to break up the toner.
Can you tell me what service call 7002:0006904 on a Kyocera FS 5030N means? Thank you
7002 is the error code; 0006904 is the printer page count.
Error means-
Toner motor 2 overcurrent detection error (cyan toner)
• The engine controller PWB (A0004)
detected the overcurrent of toner
motor 2.
Possable causes-
1. Lump of toner inside cyan toner container or defectiveness of toner replenishment drive system.
Replace the cyan toner container.
2. Defective toner motor 2.
Replace the toner motor 2.
3. Defective engine controller PWB (A0004).
Replace the engine controller PWB (A0004).
Jan 05, 2011 | Kyocera FS1120D Laser Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Canon MF8050Cn AllInOne Laser Printer Logo
22 people viewed this question
old marine
old marine
