Question about eMachines Computers & Internet
I need a location sensor installed on my pc
My pc does not have a location sensor on it. (as far as I know). How can I get one ?
  • 3 Answers
Http://www.ebay.com/bhp/mini-pci-e-wifi-gps with https://www.cartft.com/de/catalog/il/1279
Posted on Apr 07, 2014
4.6l engine. What is firing order?
Found this firing order.
As far as the sensor, you talking about 02 sensor? Bank one has the number 1 cylinder, bank 2 is the other bank, sensor 1 is the first sensor you come to, in the exhaust.
Mar 02, 2016 | 2001 Lincoln Continental
Where is the cam sensor located on a 1998 Cadillac Eldorado 4.6? How many one or two?
There is one cam sensor in the rear head on the passenger side, as far as I know there is only one.
Maybe the confusion is that there are 2 crankshaft position sensors, and they are located near the oil filter adapter
Apr 17, 2015 | 1998 Cadillac Eldorado
Coolant sensor is bad on my 01 Eclipse 2.4 L motor. I need to know where it is on my car and how to change it
Diagnostic codes # P0115 to P0119 all relate to the ECT (Engine Coolant Temp) sensor circuit.
Assuming you have correctly diagnosed a faulty ECT sensor, here are the instructions to locate and test:
* Look for a bolt size sensor with a wire attached - on Mitsubishis, the ECT sensor is usually located either on the Intake Manifold, or close to the Thermostat housing (to measuer coolant temp).
This is what is looks like:
* To test the ECT sensor:
* With the sensor portion immersed in hot water, check resistance as per the table below (convert to degrees F if necessary):
* If the resistance is too far out of spec, then replace the sensor.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | 2001 Mitsubishi Eclipse
95 chrysler sebring lx v6. I purchased this car knowing that the crank shaft sensor needs replaced, but i have no idea where its located. The salesperson at the auto parts store was trying to tell me its...
this sensor is located in the front of the motor near the crank shaft balancer, or in the rear by the cylinder head where the transmission meets the engine.
Jun 12, 2011 | Chrysler Sebring Cars & Trucks
Need to know where is Low Output SPEED Sens RPM, Above 15 MPH located in 1998 dodge durango 5.9cc 4x4. dtc code p0720
as far as i know there is only one speed sensor and it is located on top of the rear differential should have one bolt holding it in. i believe that code says the speed sensor has a low output.
Aug 26, 2009 | 1998 Dodge Durango
Ineed to know the location of the cam sensor on a ford escape 2002 with the 3.0 liter V6 DOHC
SECTION 303-14: Electronic Engine Controls 2002 Escape Workshop Manual REMOVAL AND INSTALLATION Camshaft Position (CMP) Sensor —3.0L (4V) Removal and Installation
  1. Remove the camshaft position (CMP) sensor.
    1. Disconnect the electrical connector.
    1. Remove the bolt.
    1. Remove the sensor.
#56 is the cam sensor. please rate as fixed if this is what you need.
May 02, 2009 | Ford Escape Cars & Trucks
To install my cam
Driver located on A4-Tech website. Even works with Vista supposedly. In this day and age, that is a serious plus that other manufacturers need to learn from.
Ratings appreciated as it takes effort to deliver goods to you, and far to many people seem to forget that.
Aug 29, 2008 | GE EasyCam Pro Webcam
Sensors for vw golf?
MAF is located in the air filter box.
As far as i know, ur oxygen sensor has one wire, not 2 and is black if i remember.
Jul 31, 2008 | 1997 Volkswagen Golf
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
Computers & Internet Logo
26 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
