Question about Karcher Vacuums
Karcher vaporapid 1105 manual
Lost manual. How much water do I put in and which button does what,when hot enough .forgotten
    New Friend:
Please, how can I open the water reservoir from Karcher 1501 Vaporapid?
Posted on May 29, 2015
There should be a labeled fill line on the clean water resavore
Posted on Mar 26, 2014
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
Why is my karcher wv50 blowing out water through its air vents
Have you over filled it and tipped the karcher to one side that sometimes makes warter blow out the vents give it a good shake on its side then try again.
Jul 31, 2014 | Karcher WV50 Window Vacuum
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
My Eureka Deluxe Enviro Steamer doesn't steam, I had no directions with it so I'm not sure how much water to put in it. It comes out the bottom before it heats up sometimes.It never seems to get hot...
You will need to pour two measures of water using the measuring cup or 12 oz of water. The reason why water comes out of the bottom is because the floor cloth is too wet or you had too much water in the tank
Click on the link below to view the owners manual:
http://www.eureka.com/service/manuals/70359.pdf
Jun 22, 2010 | Eureka Deluxe Enviro Steamer Vacuum
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Jul 27, 2009 | Karcher DE4002 Steam Vacuum
Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Oct 09, 2008 | Karcher K DS 5500 Vacuum
Vacuums Logo
258 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
