Question about Zebra Office Equipment & Supplies
Zebra 430T cannot reset to factory defaults
I have tried to reset the Zebra GK430T to factory defaults numerous times by holding the button for four flashes and this will not work
    Champion:
  • Zebra Expert
  • 285 Answers
Try with wwwseagullscientific.com drivers, this driver have the option to resset printer to factory default.
Posted on Jun 01, 2014
Bubbabear64
  • 2794 Answers
SOURCE: Zebra Z4M
Turn the printer off. Shut off your software. Turn the printer on. Restart your software. The software will reset your label forms.
Posted on Jun 17, 2008
SOURCE: want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
Posted on May 05, 2009
  • 257 Answers
SOURCE: I cannot get my zebra stripe s600 to print
There is a sensor that senses if the printhead is open or closed. Your printer thinks the printhead is open - so it won't print.
Posted on Jul 10, 2009
ozztech
  • 285 Answers
SOURCE: How can I reset a Zebra LP 2844 printer to factory
press the green buton untill flash 4 times, then press untill flash 7 times to calibrate and print sensor profile. turn off and turn on again.
Posted on Nov 13, 2010
ozztech
  • 285 Answers
SOURCE: Zebra QL 220 Printer Reset
download segull driver (wwwseagullscientific.com) install, go to the setings, there is the Reset to Factory Defult.
Zebra gx 430t printer when I turn it on the light is blinking green/red
Do a factory reset on the printer.
Check you printer driver settings if you are printing using it.
Jan 14, 2016 | Zebra GX430t Thermal Printer
Zebra LP2844 when you turn the power switch on the green light flashes twice then goes out with no light on and nothing happens when I push the button.
reset to factory default if needed Try driver from www.seagullscientific.cam driver, it will help to reset to factory default.
Jan 21, 2014 | Zebra LP 2844 Thermal Label Printer
Restore defaults
hold pause+feed buttons while turning on the printer. release after 10secs.
Oct 01, 2013 | Zebra S4M Thermal Label Printer
How to do a factory reset on a zebra stripe printer?
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
Apr 23, 2011 | Zebra Stripe S600 Thermal Label Printer
We have one zebra printer, Model 105-SL , its not
You can try to factory default by turning the printer off, hold down the pause and the feed buttons. While holding pause and feed down turn on the printer and count to 5 and then release the 2 buttons and the printer will return to factory setting. Typicaly when all the lights stay lit its do to the logic board being bad but sometimes you can get lucky with the default.
Jun 06, 2010 | Zebra Z4M Printer
Want to reset my Zebra 140XiIII back to factory settings?
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
I am trying to clear the memory on the zebra printer gk420d ... what is the best way to do this?
Hopefully you can read this. I downloaded entire manual from Zebra. This section is the feed button options to reset communications, calibrate, print configuration & also to do a factory reset. You will need to try the FACTORY reset. Basically while the printer is on you press & hold the feed button till it blinks 4 times in a row then release. It will blink 1 time then pause then it will blink 1-11 & pause then 1-11-111 then pause then finally 1-11-111-1111 then release. Each 1 represents a blink. I would attach the doc but system is too busy to allow right now.
Feb 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2824 Comm port problem
I believe if you hold the button down that has the green ring around it and power it back on it resets the printer to the factory defaults.
Jan 12, 2008 | Zebra Eltron LP 2824 Thermal Printer
184 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
