Question about Texas Instruments Office Equipment & Supplies
My TI-83 wont dislpay the numbers
I have takin out the batteries but i dont know how to restart it. i was using the 2nd button and the up arrow at the same time and the numbers just started to disapper and they wont come back
  • Texas Instru... Master
  • 7,993 Answers
Press the 2nd key, and RELEASE the pressure.
Press the Up Arrow and HOLD pressure.
The screen contrast will increase. Release the pressure of the Arrow key when contrast is to your liking.
Posted on Mar 26, 2014
SOURCE: TI 84 Won't turn back on
Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Posted on May 18, 2008
SOURCE: screen is all black
Okay, I tried all these things, but what finally worked for me was holding the down arrow and tapping the 2nd button.
Posted on Sep 05, 2008
  • 32 Answers
SOURCE: Calculator is Very Slow
What is probably wrong is a short in the I/O port try blowing really hard into that not joking .
Posted on Sep 18, 2008
texinst82
  • 12 Answers
SOURCE: ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
Posted on Feb 16, 2009
SOURCE: TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/ti-cares@ti.com if you need specifics on getting the calc to take an OS upload given the state it's in."
Posted on Apr 22, 2009
Why is my TI-83 screen black?
If you cannot see anything on the screen, the contrast may need to
be adjusted.
To darken the screen, press 2nd and release, and then press and
hold up arrow until the display is sufficiently dark.
To lighten the screen, press and release 2nd, and then press and
hold down arrow until the display is sufficiently light
Apr 15, 2013 | Texas Instruments TI-83 Plus Calculator
My screen for my TI-83 is turning black and I can't get it off
How to Change the Brightness of the Display
To darken the display, press the yellow 2nd button and then press and hold down the Up-Arrow button located in the upper right section of the keypad. Release the Up-Arrow button when the display has reached the desired level of darkness.
To lighten the display, press the yellow 2nd button and then press and hold down the Down-Arrow button. Release the Down-Arrow button when the display has reached the desired level of lightness.
As you go through this process, a number will appear at the top right corner of the display. If this number is 7 or higher when your screen reaches the desired level of brightness, then your batteries are getting low and may need replacing soon. This number will be approximately 3 or 4 for new batteries.
Jun 17, 2011 | Texas Instruments TI-86 Calculator
Ti-83 plus silver edition, battery drain, ive
The Texas Instruments TI-83 is a graphing calculator. It's aimed towards math and science students and lets them graph and compare functions, perform data plotting and perform analysis. It has an updateable memory for adding software applications. The device comes pre-loaded with applications too. An optional connectivity kit allows you to hook the device up to your computer, and there are also optional slide cases to protect it.
  • Turn on the TI-83. Press the On button.
  • Step 2Adjust the display contrast. Press and release the key marked "2nd" and then press and hold the arrow buttons, which are below and above the yellow half-shaded circle.
  • Step 3Go to the Home Screen. You can do this from anywhere. Just press the button marked 2nd and then Quit.
  • Step 4Perform a sample calculation to get the hang of how to use the device: Model flipping a coin 10 times. Track how many of those coin flips end up in a heads result and you want to do this simulation ten times. Press Math and the left arrow which will bring up the MATH PRB menu.
  • Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
    Where is the fix button on a texas instruments ti-83
    There is no button, but a configuration setting. Press [MODE], highlight [NORMAL] and press [ENTER]. Use Down Arrow to highlight FLOAT and use Right Arrow to select the number of decimals ( 0-9). Press [ENTER] to set the number of digits you selected. Press [2nd] [QUIT] to return to main calculator screen.
    Hope it helps.
    Oct 15, 2009 | Texas Instruments TI-83 Plus Calculator
    TI-83 screen is black
    The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
    Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
    Ti 83 plus small black screen?
    Feb 14, 2009 | Texas Instruments TI-83 Plus Calculator
    TI-83 countdown
    Pressing 2nd then the up or down arrows is how you change the contrast on the TI-83. All you need to do is press the 2nd key then hold the down arrow to get your screen back. The countdown that you saw was just the value the calculator assigns to the contrast. It goes from 0-10.
    Hope that helps!
    Jan 18, 2009 | Texas Instruments TI-83 Plus Calculator
    TI 83 screen
    I know your problem
    Do NOT HOLD the 2nd button instead just press it once and then press the arrows hard. It will work just fine
    Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
    Jan 11, 2008 | Texas Instruments TI-84 Plus Silver...
    Screen is all black
    Try adjusting the brightness by pressing 2nd key or witchever name is on yours for the Alt key + the up or down arow key(as you see fitted)
    Aug 25, 2007 | Texas Instruments TI-83 Plus Calculator
    21 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
