Question about Sanyo SR-3770S Compact Refrigerator
MY SANYO SR-LV209F outer wall are too hot when it is in use. Is this a sign of problem?
Both of its outer wall are too hot. Pls. advise whether its just normal or need repair.
2 Suggested Answers
  • 1140 Answers
SOURCE: what is the coolest temp. for Sanyo SR-LV209f... 5 or 1
On any refrigerator that I have owned, the higher the number the cooler the temperature. Thus 5 would be the coldest temperature setting. If you set it too cold, items will freeze in your refrigerator.
Posted on Aug 14, 2015
What is the coolest temp. for Sanyo SR-LV209f... 5 or 1
Aug 14, 2015 | Sanyo Refrigerators
My fridge working very good but every 2 week i found that lower refrigerator not cooling but top freezer work very well when i inspect i found ice in the air hole from top to lower. pls advise for it
That simply means that your drain line is either clogged or frozen down to the drip pan. Clear the opening then put some hot water down the drain until it runs out.
Aug 03, 2015 | Samsung CoolTech Plus / Basic Bottom Mount...
Door left open on Sanyo SR-4912 and frost on back wall, what do we do?
Best, remove food switch off, leave door open and put plenty of towels down to soak up moisture, when clear restart closing door, give couple of hours to get up to speed restock
Jul 21, 2014 | Sanyo SR-4912M 4.9 cu. ft. Counter-High...
Signature sr 100 remote sanyo tv please help reprogram
can you please give more detail on your remote control ?
thank you,
dan
Thank you.
Dan
http://www.rylwy.com/
May 20, 2014 | Electronics
MY REFRIGERATOR'S EXTERIOR WALL ARE BOTH HOT WHEN IT IS RUNNING. HOW TO FIX IT?
It is possible that the condenser coils are located in the side wall panel. This is fairly normal is small refrigerators.
Mar 26, 2014 | Sanyo SR-3770S Compact Refrigerator
My Sanyo SR-4911m refrigerator does not cool. Compressor seems to turn on when termostat is turn from off position to on position. However, compressor gets really hot and gurgles, but does not cool the...
it shouldn't be gurgling, has it been laid on its side at some point? anyway,, sounds like it has air in the system,, unplug it and let it stand upright for 24 hours, if the problem still persists,, it may need to be charged, the compressor getting hot is normal , if its very very hot, its because its running constantly trying to cool the unit
Jul 04, 2011 | Sanyo SR-4911M Compact Refrigerator
How do you change the thermostat on SR-4910 refrigerator
FIRST: MAKE SURE YOU UNPLUG THE POWER CORD FROM THE WALL.
OPEN THE COVER FROM THE EVAPORATOR COIL DISCONNECT THE WIRES, UNSCREW THE BRAKET AND PULL IT OUT. ALWAYS USED THE SAME TYPE OR EQUIVALENT.
DO THE REVERS TO INSTALL THE NEW ONE
Oct 24, 2010 | Sanyo SR-4910M Compact Refrigerator
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Sanyo SR-3770S Compact Refrigerator Logo
26 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
