The strip of metal between the freezer and fridge on my whirlpool side by side is very hot. Also, the freezer isnt keeping things frozen and the fridge isnt as cold as it should be. The temp is adjusted to the coldest setting for both sides of the unit.
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool 25.6 cu. ft.
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with...
model #ed2fhexlq, cooling stopped in the fridge side and all ice and frozen food defrosted in the...
(More)
model #ed2fhexlq, cooling stopped in the fridge side and all ice and frozen food defrosted in the freezer side
Refrigerator side - bottom bin "Convertible Vegetable/Meat freezes produce solid. Temp controls...
(More)
Refrigerator side - bottom bin "Convertible Vegetable/Meat freezes produce solid. Temp controls are set on the recommended settings - have tried to adjust but nothing stops the freezing problem. Serial number = SU4239733, Model number ED2FHAXS004 Side by Side
