Question about Panasonic DMR-EZ17 DVD Recorder
Recording As soon as I put a dvd-r into the machine, STOP appears on the recorder and I can not record? Same with a dvd+r. Thanks, Jim
Your blank dvd might be the wrong speed for that dvdr
Posted on Feb 17, 2008
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Recorder records for approx 1 min the self checks
are you using dvd r or dvd rw discs ?? the r disc cause less of a hassle i have been told hope this helps regards Jim
May 04, 2009 | Panasonic DMR-E55 DVD Recorder
When deleting a film previously recorded on my Sony DVD recorder the amount of available space shows 650k as opposed to 800k despite the fact that I have no other recordings held. Can you explain why this...
Jim, Although you have deleted the recording the DVD recorder still sees that space as have been being used. The space should be reusable however the area has been used before (therefore not considered unused space).  By deleting the recording you should have no problem going over the area when it is needed.  Happy Recording Rob
Feb 27, 2009 | Televison & Video
DVD recording
WH Smiths DVD+RW discs don't work on this machine
Dec 21, 2008 | Philips Televison & Video
DVD player won't record full time that is programed into it
There are two things are likely that can cause this: media and copyright protection. If you use DVD-RW or DVD-RAM, you should be able to copy shows ONE time onto the DVD. If you use DVD+RW, or DVD+R, it may issue a copy protection message just before it stops recording.
If the media is bad, it can also cause the machine to stop recording, I believe. You could put it into a PC and try erasing the contents before re-trying to use it in the DVD recorder.
tom
Dec 19, 2008 | LG DR787T DVD Recorder
DVD disc recording
Certain disc only work in certain recorders - I know this sound weird but you must find the disc that is compatible with the recorder that you are using. If the TDK discs is working continue to use the TDK discs. Even though the format and the specifications are the same on both disc, the readers does not read all disc.
Mar 29, 2008 | Televison & Video
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Dec 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Recording problem
you need to make shure you get the dvd ready i suggest buy a dvdrw but it in the dvd go to the setup page and in there hit disc it will atomaticaly prepare the dvd cause you cant just put a dvd in and record it needs to prepare (open the disc) also if you are going to watch the recording on another machine after recording you need to finalise the dvd when they ask you to or it will only work on the rca machine
Sep 29, 2007 | RCA DRC8052N DVD Recorder
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
Panasonic DMR-EZ17 DVD Recorder Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
